i just bought an alarm
*edit* brand Invincible Super Duper unstealable car security system
details: under car flame thrower function
its a simple shock sensor alarm with all the standard gizmo stuff with remote engine starter
questions:
-how much am i looking at in getting it installed?
-it has central looking system, and looking at my skyline, the central locking only locks the passenger side, not the driver side. is there a way i can work around this or do i have to buy that crap that makes both doors look
-do i have any chance in doing this myself with little electronic knowledge....haha
and yes im poor, i want to find cheapest solution
but it looks like its gonna be expensive
any help appreciated.
https://www.sau.com.au/forums/topic/15202-fitting-alarm/
for the passenger side you can just get another motor fitted replace the one that is currently in there. These motors arent to expensive but i would buy one through the place you get it fitted at as ive had 2 motors replaced since my alarm installation. I'm happy to say they were covered by warranty. central locking motors are bitches and sometimes break as most of them have plastic cogs
https://www.sau.com.au/forums/topic/15202-fitting-alarm/#findComment-309783
No probs with mine.. had to adjust it up a couple of times but otherwise fine.
So you have to actually use the key to unlock the drivers side? hmmm, doesn't that spoil the point of a remote immoboliser thingo dingo? I think it can be done by yourself or with some help - the main thing is just to find all the points you need to wire into. If its not skyline specific can be difficult.
Some will require pulling the door trims off, some the steering wheel guard cover, and some stuff routed thru into the engine bay for things like the alarm siren, etc.
  Quote
This alarm will protect your car well because got a full sensors to protect body, windows and doors (Connected to door switch)
i still luv this engrish! :P
https://www.sau.com.au/forums/topic/15202-fitting-alarm/#findComment-309935
okay - i would say if there is already an alarm in there its going to have to be removed... then the install, which can take a bit of time with things like remote start.
I would say your looking at around $180 including door motors etc. Just a guess tho. Dont forget most these guys charge by the hour and something like this will take maybe 4hours...
https://www.sau.com.au/forums/topic/15202-fitting-alarm/#findComment-312038
