Hello all,
I have done a search on this problem i have on the forums and have got a bit of information, some of which seems to contradict the other. So just wondering if anyone has experienced this/knows a fix for it. Here goes:
I took the car for a wheel alignment and balance cause i had bad vibration over 120km/hr. Guess what? It's still there. It's violent between 120-130km/h. I've noticed that at 120km/h it vibrates through the steering wheel. 130km/h, the vibration in the steering wheel is less, but the console (where the radio a/c is) shakes like hell. At 140km/h, the vibration moves to the drive shaft/rear i think. Any ideas on what this could be or how i could fix it?
Thanks in advance!
Cheers,
Eek
https://www.sau.com.au/forums/topic/15208-help-with-vibration-problem/
sounds like ur wheels aren't balanced, try someone else to balance it... also test the pressure of the tyres, try not to use the ones u find at the petrol stations cause they aren't very good, i find that my tyres don't seem to hold pressure very well so i have to keep pumping air in every now and them ... but yeah ... most of threads like this i've seen were fixed with proper balancing... are the tyres new??
i think its an unbalanced tail shaft, on my vl (yeah its not a skyline) i had a 2 peice tailshaft, wheels were ballanced and alligned propley, coudlnt work it out, but it would be find till i did 160 and it would vibrate like hell. i replaced the center berring thinking that was ruined, didnt do anything.
my car was so bad once backing off at 240, u would think it was going to drop the box and send the engine outa its mounts.
i then got the tailshaft ballanced and everything was fine.
have you hit anything under the car? the slightest knock on a tailshaft can put it outa ballance.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
