Selling my 32 to make way for an upgrade =) details are below.
WAS asking >>>>>>>>>>>>>>>>>>$11500
Was asking >>>>>>>>>>>>>>>>>>>$10500
NOW ASKING ONLY >>>>>>>>>>>>>>$9500
1993 R32 Gtst
Trans: Manual
Colour: Red
Mods:
- Bee*r 3Inch turbo back exhaust
- Large FMIC
- KYB Suspension
- 500hp Bosch
- Turbosmart Boostncontroller
-Blitz dual stage turbo timer
-Greddy Boostguage
- CD player with new speakers back and front
- GTR Breaks and spoiler
- Clutch just replaced with receipts for proof
Any questions feel free to pm me. Looking for about 10500 neg or only willing to trade for a manual wrx or a r33gtst or r34gtt plus cash your way. Located in southeastern suburbs melbourne.
mobile: 0412 128 622
email: boostncruize@hotmail.com
Edited by Bo0oSt
https://www.sau.com.au/forums/topic/152092-sold/
come on any takers who want some extra cash behind them in melbourne ???? id really like a r33 :D
Car has been regularly serviced and taken care of....so someone buy it or offer me a r33 =)
Edited by Bo0oSt
https://www.sau.com.au/forums/topic/152092-sold/#findComment-2833861
got about 150k on the clock
theres some engine pics havent got any interior ones atm will post em up moment i get them but its just your normal 32 interior no burns or anything
https://www.sau.com.au/forums/topic/152092-sold/#findComment-2881250
hey mate, spoke to you on the phone, heres the link to my car
http://www.skylinesaustralia.com/forums/in...howtopic=157283
was after at least 7.5k on top to give to my dad.
let me know what you think and then we can take it further or not
cheers
Billy
https://www.sau.com.au/forums/topic/152092-sold/#findComment-2924983
  • 3 weeks later...
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
