Ive checked out a few places and the quotes to get a fibreglass 400r sprayed in white are:
$320
About $300 (verbal)
$400
over $450
Anyone recommend someone that can do a good job but maybe a little cheaper? Ive got quotes from FIbrevision and Cowley smash (cheapest 2).
Thanks
https://www.sau.com.au/forums/topic/152106-front-bar-spray-quotes/
$320
About $300 (verbal)
$400
over $450
Thanks
Thats weird I was quoted only $150 to spray my front bar (JUN) by Fibrevision "provided I sand back of course"
Had a few other quotes and none were over $300!
Is it Brand new front bar? If so should be fairlly cheap!
them prices u have been quoted are pretty good. $350-450 is about the average price to get a bumper painted. Bein fiberglass it will cost a lil more cos there is always some sort of extra prep wor required (eg: pin holes, gel coat blisters or just marks left from the mould).
A 400R bar has slightly bigger vents meanin tricky angles to spray at and is generally bigger than a standard bar so another reason costs more
mike
hmm i really should register my own username hahahaha
Just had my front bar 400r painted in pearl white. Cost me $500
The guy had to sand it down and prime it 2x then 3x coat of paint and then 2x clear i think not too sure on number of clear coats. It was painted by nick alberto`s in Osborne Park. These are the guy`s that do all the paint work for Alf Barbagello`s so they are used to doing ferrari`s,porche,lambo and all those exotic cars.
Its getting put on the car next week by Ken at hyperdrive along with all other mods going into the car.
Got 2 quotes yesterday!
"For Pearl Black respray ; front bar and bonnet"
Needs a fair bit of prep work!
1st quote: $290
2nd quote $350 (includes bracing front bar to restrict movement)
However I am just out of perth atm! I thought perth would be cheaper as in more competition but yeh not the case!
nearly every painter is gonna opt for "blending" adjacent panels when painting a car. While its not impossible to match a colour edge to edge perfect it does take a long time. I have spent up to 5 hours just tryin to match a colour.
With spraypainting bein on such a tight profit margin it is alot easier and quicker to to mix the colour to say a 95% right colour match then flick the colour and clear over any adjacent panels.
This may sound a lil dodgy to any1 not in the industry but this is actually the recommended method by the more reputable paint companies.
mike
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
