hey does anyone know anythin about these?
i got my car registered an sice ive put an aftermarket steering wheel, hks ssqv, apexi air intake, and an exhuast...should i have a mod plate for any of this gear ive done it all myself,
soon to come is an sparco seat power fc ebc and fmic, mod plates for these?
if so where do i get em?
https://www.sau.com.au/forums/topic/152156-mod-plates-in-queensland/
We have everything on ours modded, just incase. But the problem with this is, even if you DO have the plate, they can say to you 'how do we know you haven't changed it since then' and fine you anyway :sleep:
according to those modification links i provided you, any aftermarket steering wheel fitted to a car with an airbag is defectable and you'll receive a fine for it.
fitting an aftermarket steering wheel to a car with no airbag fitted from factory is allowed based on the size of the steering wheel in accordance to the modification rules/laws.
the hks bov you won't be able to get a mod plate for, and you can get booked for it unless you have it plumbed back.
when you get the seat you will need a mod plate. just ring either a cop shop, or qld transport and ask them where somewhere is that does mod plates in your area.
BOV is allowed however, he'll get fined for undue noise and that is it.
Maby so, but there was a court case 18 months ago about a guy fined for undue noise for having a BOV.
His defence was that trucks and buses with air brakes have air bleed valves which operate at much higher pressures and hence emmit more noise... The judge agreed with the Police that a BOV is distracting to others however he could not be fined for undue noise unless the officer wanted to fine all busses and trucks for the same thing...
So technically an officer could fine you for dangerous driving, as the dangerous driving act has a clause about distracting other drivers... But i dont think it would hold up in court, as most peoples thoughts on dangerous driving means that the driver was speeding excessivlly and driving like a idiot. So the dangerous driving tag would probablly get over thrown also...
    • With stone chips, you really can't just try to fill them. You really have to sand that spot to lower the edges of the chip, so that the filler will end up covering a wider patch than just the chip. Otherwise, you're trying to have a sharp edged paint surface match up to some filler, and they just do not sand the same and you always end up with a noticable transition. A bunch of adjacent chips should be well sanded back, to round off all those edges, and use a lot (in a relative sense) of filler to raise the whole area back.
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
