Here are some web sites that helped me when I was studying for the JLPT last year.
http://www.jlpt.info/
http://www.joepark.org/joesjlptpage
http://www.jlpt-kanji.com/
http://www.kanjisite.com/
http://kanjichallenge.com/
http://iteslj.org/v/j/
http://www.geocities.com/ryuchan1/
http://www.tanos.co.uk/jlpt/
http://www.mlcjapanese.co.jp/Download.htm
Some helped quite a bit so if you are studying a bit of the ol' nihongo yourself, then be sure to check them out.
https://www.sau.com.au/forums/topic/152159-students/
Hey mate, thanks for those links. Was just checking a few of them out. I have been studying for about a year and wanted to do the test last Dec, but due to circumstances couldnt get to. How did you go with it? I have found that the written and spoken grammer is a hell of a lot different.
Again thanks for the links
Cheers >_<
https://www.sau.com.au/forums/topic/152159-students/#findComment-2837731
I'm no expert but Japanese doesn't change that much from other languages in that the spoken and written language is different, nobody in any language speaks like a newspaper. Although it is compounded a bit in Japanese because you have distinct polite and formal ways of saying/writing things, but it is not too hard to master.
Dunno how I went, the results come out in mid February. If you are trying to learn Japanese, taking the test is a great way of motivating yourself to study, considering it's so expensive and is only held once a year.
https://www.sau.com.au/forums/topic/152159-students/#findComment-2842050
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that ne side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
