Anthrax....R33 Posted January 17, 2007 Share Posted January 17, 2007 hey guys i need to know...how to reach my positive ignition wire? do i need to remove the dash? im supposing its red? also where have you guys found the best for running an earth? any help would be much appreciated Link to comment https://www.sau.com.au/forums/topic/152223-12-volt-ignition-wire/ Share on other sites More sharing options...
Anthrax....R33 Posted January 18, 2007 Author Share Posted January 18, 2007 lol its all good......i tapped into the ciggarette lighter Link to comment https://www.sau.com.au/forums/topic/152223-12-volt-ignition-wire/#findComment-2832659 Share on other sites More sharing options...
Gazee Posted January 18, 2007 Share Posted January 18, 2007 Its not exactly the best idea getting it from the ciggie lighter... best to go to the ign barrel and get your ign and then earth on metal just incase it over loads the circuit of the ign wire then keeps popping fuses. But i suppose if it does just put a higher amp fuse in.. good luck dude! Link to comment https://www.sau.com.au/forums/topic/152223-12-volt-ignition-wire/#findComment-2832686 Share on other sites More sharing options...
Chris Rogers Posted January 18, 2007 Share Posted January 18, 2007 good way to fry cables you know. if its a blitz item grab the diagram for it off the blitz site OR grab a blk/red wire off the ECU. that has a 10a fuse on it so whatever you tied it to is safe. Link to comment https://www.sau.com.au/forums/topic/152223-12-volt-ignition-wire/#findComment-2833530 Share on other sites More sharing options...
