hey, am just trying to help a friend out, some of the details are a little vague. basically, pump is fine, no leaks, fresh fluid, but the hicas/power steering cuts in and out, and ideas?
1. no i havent driven it
2. no i cant get any better details than that right now
https://www.sau.com.au/forums/topic/152229-r32-gtst-hicas-problem/
Hey when you say cuts in and out, is it normally when u have drain? Mine starts jerking if im in traffic with the lights on or sitting still with power drain to long.. have been told its the alternator, tried replacing battery and it didnt fix it.. when it's jerking the power is pretty low, voltage wise.
yeah, while i was there with em, they both were checking the boot, and they couldnt find it, they were specifically looking around under the parcel shelf. i didnt look myself, but saw them inspecting it. have to have another look tomorow maybe....
do people often move the HICAS electrics for audio installs? he has an amp and sub just sitting in the boot, but not under the parcel shelf, stuff just sitting there, so shouldnt effect it.... maybe some dodgy audio wiring has something to do with the problem?
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
