Im selling genuine HKS 2530s to suit any GTR, they have travelled 9000kms and are in very good condition. They made 320kw on my car but were only pushed to 16psi as I ran out of injectors. These are great turbos, they come with genuine HKS dump pipes and Garrett actuators. Im after $2000 for the lot, call 0433 566 080. Melbourne Northern suburbs.
nice deal these won't last a day
yeah but that wont stop some ballbreaker offering $1500 for them.
these are the best all round turbo's to suit RB26's i highly recommend them
Ill have some pictures up tonight, I believe theyre one of the most responsive turbochargers available for the 26, my car had 320kw, ran a best of 11.4. They truely are one of the best streetable upgrades around, they come with genuine HKS dump pipes, not chinese copies. I had full boost at around 3200-3500rpm, they start spooling almost instantly.
i just bought 2860r-5 garretts. wish these where here a month ago,would have saved me 1k..good luck mate...what ya upgrading 2
I would love them but need:
Full major service = $500 (I know a guy)
4 new tyres = $800
Bummer!
buy the turbos hehe...the old ceramic are shit..i just upgraded...
Ill have pics up tomorrow, battary was flat in my camera, I just bought a T51r-BB, I paid close to 5k for the 2530s with the dumps, I cant believe nobody has snapped them up yet.
    • OK, that is a helpful description, because that sounds exactly like a bleeding issue in the clutch....these are hard to bleed manually even when the damping loop has been removed. I'd suggest bleeding again....start by filling the master cylinder up and opening the bleed nipple. Come back and check every now and then that the master cylinder is not empty. Let it gravity bleed for a few hours and see if that improves
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
