[EOI] R32 Gts-t Type – M
would like to see if anyone is interested in my car since im going to upgrade to something new.
1992 model
Manual
Silver / Blue
Km ; 181 ****
Rego; 7months
Engine;
Full exhaust System.(includes; am performance front/dump pipe, high flow cat and aftermarket cat back)
Excedy Heavy Duty Clutch
Custom fmic with piping
Chrome polished intake manifold with repositioned throttle body
Turbosmart boost Tee controller.
Turbosmart bov
Ems stinger ecu
Dna pod
Bosch 040
Exterior
Gtr rear guards
N1 side skirts
Trust rear pods
Aftermarket Rims chrome lip black spokes (18x8/18x9.5)
235's at the front and 275's at the back
The car was putting out 174kw atw on 14psi this was dynoed before the front/dump pipe was installed..
does not have any problems or has drop a beat since.
Looking for $14,500ono
If you are after more info please pm me
khon.
http://i114.photobucket.com/albums/n278/aveabat/CIMG0642.jpg
http://i114.photobucket.com/albums/n278/aveabat/CIMG0631.jpg
http://i114.photobucket.com/albums/n278/aveabat/CIMG0687.jpg
http://i114.photobucket.com/albums/n278/aveabat/CIMG0663.jpg
Edited by MASACR
https://www.sau.com.au/forums/topic/152255-r32-gts-t-type-m/
    • Haven’t had the chance to drive it yet with work being a nightmare, will definitely be doing that at some point this week. got these so that grip won’t be an issue at roll racing
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
