My turbo is screaming when it reaches the set boost level.
Makes normal spool up sound while getting there but makes a horrible sound on full boost.
I've varied boost from 10psi to 18psi and the sound is only there when it has reached this level.
Power has not been lost, oil pressure/level and quality are good.
A local workshop suggested that the shaft bearing may be loose or worn and the exhaust wheel is touching the housing????? Either that or it's a blockage in the oil feed line and the noise is from the bearings running dry.
To anyone with knowledge does that sound right or should my turbo have blown up by now???
Could it be something to do with air getting in or out of somewhere it aint supposed to?
The Turbo is an old HKS T3G with an internal wastegate.
https://www.sau.com.au/forums/topic/15227-screaming-on-boost/
yeah happened to me and it ended up losing boost and the flow out the end stopped.
i just high flowed the trurbo and it works fine now
but there was not much movment inside the turbo and it looked fine from outside.
but get it looked at and rebuilt.... but do it before u start losing boost. cos it wil happen if the same prob as mine
at first it would only happen at high boost but then slowly worked it way down and then boost would come down with it.
cheers
Thanks to all for your replies.
Doesn't sound good. This may be the start of some serious rebuilding.
It's definately not a belt. Time to rip the Turbo off I guess. Maybe I'll find out now what a HKS T3G is. I now it's been good for over 200 rwkw so a bit of rebuilding might see more.
Cheers fellas
Could it be your exhaust manifold. Mine schreeches at 6,000 rpm (not bad) just noisy. The guy's said some manifolds come lose after time, so the air escapes and makes that noise.
It might not be the problem, but it's one to keep in mind....
Cheers
Loz
Lozza150's right on the ball. The screaming noise you're hearing is air escaping from between either the exhaust manifold and the block or the exhaust manifold and the turbo. My car did the same thing, you'll probably need to unbolt it, replace the gasket and re-bolt it back up.
Cheers,
matt
Adam,
Yeah but his car doesn't seem to have any problems making boost, which would indicate that there isn't any damage to the turbo...
I've had a busted thrust bearing on a different turbo which caused the compressor wheel to grind itself into the housing... This didn't even make any noise, the car just wouldn't make the same amount of boost!
matt
I agree that it sounds like an exhaust gas leak, a friends VL turbo made a similar noise, he took it to a so called turbo mechanic who said it's rebuild time, before that he thought he'd check it over himself and discovered that the bolts from the turbo to the manifold were loose, I believe the turbo shop would have thought that all along and would have recieved $800+ for simply tightening a few bolts.
the worst part is most of the cost is to take off all the bits to get to the manifold.... you may as well Hi flow or rebuild the turbo while it's off.
Well that's what I'd do... Hence why i'm not going to fix the exhaust leak till i can afford to hi flow the stock turbo...or fit a HKS gt2540.... (Yeah right)
Loz
Cheers again for your replies. I believe it is more along the lines of a gasket leak too.
I'll have a good look Saturday and post back what I find for any other people curious.
By the way my Turbo aint stock and I don't think HKS would approve of someone going to their handy work with an air grinder.
A rebuild maybe, but if it comes off I'm hoping it can go straight back on again.
I'm getting really toey running around town without letting it build any boost.
The slightest hint of waistgate chatter is enough to get me going. ch ch ch ch ch to to tooo.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
