A tuner ive been speaking to has reccomended i ditch my standard coil packs as they prove to be unreliable (due to age and heat) past the 500rwhp that im after. The computer i want to use (well might) only has 4 coil outputs which is part of the reason im looking to change
Ive seen it done here in NZ a few times using VN commodore parts however im a bit weary of having anything from a vn commodore in my engine bay. Ive very rarely seen it done on this forum however.
What info has anyone got about doing this? He mentioned using LS1 parts?
https://www.sau.com.au/forums/topic/152271-external-coil-packswasted-spark/
don't do it.
1. buy a computer with 6 coil drivers
2. buy splitfires
3. never have to worry about misses again
why, that comment doesnt at all help? you may as well have not posted anything
a wasted spark system is a few hundred and splitfires are 600 + the computer difference is 800 hense the reason wanting to look at changing
I have an external coil pack out of a commodore with a MSD DIS4, and have had no problems.
Its obvious that the heat generated around the standard coil packs effect there reliabilty.
I have them on a bracket which is mounted on the side of the plenum.
Splitfire coilpacks are waste of money so i have been told.
Edited by subzeroR33
Ok,
I will give a more in depth analysis.
The reason people replace coils is the factory coils are past their MBTF and are developing faults. If you were to get a brand new set of coils as spare parts from Nissan they would perform exactly the same as the splitfires. This is because they are from the same factory and made under the same manufacturing process.
These coils are designed to charge and discharge in very short periods of time as required by a turbocharged RB at 7500rpm. Providing you have adiquite ground and no earthing issues you will not have any problems with them.
Wasted spark ignition will use 3 coils that are designed to discharge a lower amperage spark and are not used on turbocharged cars for this reason. you will also have 2 other points of failure or possible failure. The leads... You also need to know the resistance of the new coils to set the ignition dwell. None of the wasted spark coils will have this data available thus possibly burning out the coil drivers or coils.
You also do not want to see what happens to a turbocharged engine when it leans out with a wasted spark ignition system due to fuel cut.
Also once you buy 3 coils, 6 good quality leads and hack up your engine bay you will be looking at atleast $400. for $200 more you can have the splitfires delivered to your little house :(
I have splitfires in my car running 19psi on an rb 20 pushing 240rwkw. they took me 1/2 an hour t put in and I never have to worry about ignition again :D
my 2c
Thats all good in theory, except the recharge time never comes close the the total spark cycle, waste spark works fine on turbo/high revving motors, mitsubishi evo's, mazda rotaries etc. The coil recharge time on nissan coils is low due to th compact nature of the coils, not the high revving nature of the motor. If splitfires and nissan coils are exactly the same, why do splitfires run well with more dwell time? I believe that splitfires have a slight varience in the number of coil windings, and maybe wire gauge, but until someone pulls one apart, noone can be sure. There isa fair bit of info about doing a waste spark setup, and i think its a great way around the pricy problems with the nissan setup, just steer clear of the early commodore types, as they are known to have problems, or even better get the msd coils, and you can give them heaps of recharge time so they have a nice fat spark.
Ok heres a good reason
Does everybody know that when a ecu says it can run 6 invidual Coils that it fires them in wasted spark
Noooooooo they dont do they. Well maybe people should check there ecu as 90 % of AMECU`s do
And who said wasted spark doesnt run Correctly i have used it on mine and so has thousands of other high hp turbo cars.
Cheaper and more Easier to use.
How hard is it to farken check timing with coils
Its for the bin
Plenium Leads and Top mount the Way to go
Dwell time on Standard coils 2.5
Dwell time on Splitfires 3.0
Dwell time on El coils 3.5
Dwell time on msd coils 3.8
Then on top the EL coils you run A MSD DIS4 which if you get zappppedddddddddddddddddddd by you`ll know it. hahahhahahahahahhaha
THen you see your spark about 10 cms long
i know trust me
Edited by MR331307
I use wasted spark on my rb30 i brouht a new vn coil pack for around $100 the leads cost about $60. I changed the dwell time to 4ms(link ecu) and at idle you have to pull the lead a long way off of the plug for it to drop that cylinder then you get a bloddy big shock.
lol
I made 369rwkw/24psi on stock coils
And i've seen many an RB26 get over 400rwkw stock coils... they cant be that bad :(
Just get a HKS box and it'll give you the extra oomph needed, thats why they make em :happy:
whats the fastest time you have run
What's that got to do with anything??
I'm sure the discussion is on coils... :(
Oh, and I guess it depends on what you want, there's quite a few GTR's running over 400rwkw with standard coils, but running the HKS Twin Spark...
I'm running this setup and have never had issues with spark...
Harsh... especially when you are saying the computer is $800 more.... I know of one ECU that runs six ignition drivers for about $1000.
Adaptronic I think its called, search on that one.
Also, if you wanna go with a better known brand, Microtech LT12s is NOT $800 more than the LT10s. Its only an extra $300 I believe.
I've often wondered why not just run 6 bosch coils with leads to your plugs. Should only cost a few hundred to set up and pair that with the adaptronic, you get the whole setup for under 1500 i'd imagine... if you can wire it yourself. Id do that if I had an RB engine in need of coils and ecu.
  • 3 weeks later...
Yep, using them on a starion, dial up 4ms dwell time, so far making 240rwkw with two coils, so should be fine for at least 360 rwkw on a six. It certainly helps to upgrade the power and earth wires to reduce voltage drop, And adaptronics are great valuewith more features then anything of the same cost.
cheers mate, thats good info
so your using the evo coils then? what did you pay for them out of interest?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
    • I actually have an aftermarket hanger, the detschwerks x1 hanger, but my dw420 has never really sat in it correctly, good to know I can just modify it a bit to suit. Yeah cheers man will definitely have a play with it and hope it solves my dramas.
