On 18/1/07 6:11 PM, "gary martin" <[email protected]> wrote:
i was wondering if you would mind if i posted this in the west australian events section of skylines australia.com forums for more feedback coz a heap of skyline owners dont read antilag where i saw the post about it
No worries man
Go for it. Just let them know that exact date and location are’nt finalised but will be by the end of next week I’d say.
Let people know im looking for cars too
see i have permission Dan :D:)
Hey guys
giving you the heads up that Ignition DVD is hitting Perth again in Feb. We're flying over to cover the Drift Australia round.
I'd like to stay for a week but to do that i need material to cover so give some feedback on your thoughs of doing another massive hotspots. Id look at doing it on Friday 23rd ( night before Drift Australia ) or the Friday after , but that would onyl work if we have enough cars to feature the follwoing week.
So ive you think your car passes the grade or your mates does start emailing pics and detials to:
[email protected]
the more stuff we have to shoot , the longer we will stay. jsut remeber that we wont be back for a while after this trip due to schedule for the year so make the most of it.
  • Replies 169
I went to the last one
It was crazy at galleria undercover carpark, full as. people walking everywhere, like a mini car show.
Get the dickheads rocking up too dropping skids, good to see though!
Yeah! It's awesome to see people doing burnouts around other cars with groups of people standing all around them! :)
My car is mostly go and all most no show, so pfft, maybe ill take my Nana car for a look see anyway
Thats ok Keets mines mostly show and no go - so if we combine both our cars maybe we'd make the grade :P
    • $53.35 and a double din Pioneer head unit that I have...
    • Put a camera facing your dashboard so you can film the gauges. Head out to a straight but of road, and filming it as you go from a stand still at wide open throttle to as fast as you can/feel comfortable doing. Then film the dash board as you for example accelerate like normal onto a freeway. This will give us an indicator from Speedo of your expectation of slow, and will give us the rpm reading too to see if it's shifting. (Auto still has tacho from memory)
    • Buy yourself the cooling system pressure tester. Being able to pump it up, and have a gauge on it, AND have a cold engine makes it much easier / practical to diagnose. Additionally as the engine isn't running, you can listen for pin hole leaks as well as watching if pressure drops away. In addition, you can pressurise and while doing so, watch all the little rubber hoses. Some fail very brittle, and will just leak, while others can end up very soft and bulge. While a bulging hose isn't necessarily leaking, one of those small ones starting to stretch / expand in a bad way is an indicator that you'll be looking to replace that one soon   Depending on if this is a project car, or you'll be dailying it in the summer months would alter how I'd be most comfortable with driving the car and how I'd replace. If you're planning to use it as a daily, with no backup, I'd pull the engine, and replace all the external oil/water lines in one big swoop. At the same time do the timing belt, water pump, tensioners etc. Do not open the engine at all. We just want to replace all the things that are inexpensive as a single item, but a PITA when they go. By doing the above, you've made the car from a bunch of age related issues more reliable. If it's a project, and you like swearing while trying to reach into dirty hard to reach places to replace a single hose that may or may not be the leaky one. Just replace the leaking/bad ones as they need it. If it's a project and you'd rather swear at the car once and enjoy it as much as possible, then refer to the process I mentioned in how I'd want to do it if it were a daily. However, the approaches above do come down to how much spare pocket change you have. Pulling the engine and dropping over a thousand dollars on parts, may not be practical for you. Oh, if engine outing, I'd replace as many silicon/rubber inlet joiners as possible too.
    • Yeah, they're pretty dumb though...ie; they'll throw a solenoid error if the solenoid is dead, shorted, wiring is open circuit, or even if the driver transistor has failed (they can't self-diagnose much, they can only test inputs/outputs)... but if you wanted to try, I believe it's this protocol....(uses a long pulse indicator with short pulse counter)...
    • Yeah I'll do what I can without taking off any major parts for now. If it becomes clear I won't get far with the engine in the car I'll have to think about the next steps. I am not too stuck on keeping everything 100% OEM, if there is better solutions, like converting most lines to braided with AN adapters, I'd rather do that than buy overpriced new "shit" parts.
