WTF
I did not, and i will state that twice,
I did not throw a bottle at the police. I expect a retraction on that comment, or at least a clarification as to why you said that Kym. People will believe that shit and I can happily say right now I would never throw a bottle at a policeman (or anything else for that matter.)
i heard u threw a bottle at the police
please discuss
  • Replies 169
speaking of parents, when the cops followed the blue vn into the car park and started looking at his car, some father, son and mum went up to the cops and the dad started telling him that it was bullsh*t how they were harrasing him, they told him to go away or he would be arrested lol
I think power fc is better then wolf
Please discuss.
bahahahhaha f**king gold!!!
i just sold my d-jetro for the new wolf v-500, i'm just trying to find someone who can tune it without it pinging?!?
maybe its just wolf advancing my timing cause it doesnt use knock sensors?
Too many bogans really let it down. Big turn out, but half of the cars were boring factory falcons and commodores. f**king ordinary SS', FPVs and and HSVs, WOO! SO EXCITING!
Yeh cause an R33 Skyline is rare as f**k.
This wasn't an import only event.
yeh a few ppl were complaining about trrevs, i think dunnydores are crap, but there were many modified cars, and i can respect that, and as stated it wasnt imports only, so it was good to see a bit of diversity
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
