Turbo was hiflowed through turbo australia.
plain bearing, steel wheel, 270 thrust bearing.
power fc, z32 afm, 550inj, fuel reg, walbro fuel pump, FMIC, AVCR.
set on 18psi
i noticed compressor surge on about 5 psi on the highway.
have tried changing from my turbosmart bov to a standard one, no difference.
have an adjustable actuator, what can i do to fix this annoying surge.
who should i speak to?
https://www.sau.com.au/forums/topic/152280-how-to-fix-compressor-surge/
ideally try and monitor pressure at both ends to try and isolate it
compress surge occurs when pressure past the compressor wheel exceeds what the compressor can actually supply, ie say hiting 27psi and the compressor can only yield 15psi etc. it surges violently. perhaps the bov is leaking or not closing properly? checked for obvious leaks ?
sorry i am a goose
the bov is opening as part of the pressure spiking
what happens is the compressor is ramping up boost
the pressure spikes significantly and the bov is opening to dump the pressure
but its probably spiking really high and quickly so it makes the wheel surge too
i dont think the bov is at cause here, i think its the compressor wheel
surging while ramping boost is common with highflows, well more so than a off the shelf spec turbocharger
speak to the people who hiflowed it
The only other thing is when i installed the turbo
i still had stock injectors and afm, turbo was sitting on 12psi
with my standard airbox.
i didn't witness compressor surge at all,
then when i installed pod, 550inj, fuel reg, and z32 afm and put it to 18psi, thats the only time it started doing it.
I even dropped boost back to 12psi and still does it.
Anyway, i have sent a email regarding whats goin on to the turbo mob and i'll see what they say.
I have my car back from my tuner
everything else is awesome on my car and thanks heaps to my tuner
a/f ratios are at 12, the rb20 adjustable actuator i put on my car, cause i thought it might of caused the problem didn't help. My tuner ended up fabricating a replacement adjustable rod, as the original was rusted out and couldn't be turned.
from looking at it, we think its the bov, either lost tension and is bouncing, forcing air into my intake pipe, inturn dumpin fuel into my engine, bringing the a/f to 10.
The bov as been wound right to hard, to stop the bouncing and has seemed to hold up, as i have the car back and hasn't done it.
Turbosmart also believe running another tee into the other intake runner could possibly dampen the pulsation, suckin excess air from the bov.
Anyway i thank my tuner heaps, has looked after my car, and has contacted me whenever news arised about the tune, or anything to do with the car.
Will not hesitate to take the car back to him, if anything happens, or for future mods.
i also have notice that i had my bov connected too two sources
one: is my boost controller
two: the vaccum line off the plenum
i have been speaking to turbosmart, and they have said that this could be the problem.
so im going to change my setup i have and just have the bov connected to the vaccum line only.
then the boost controller solenoid to the vaccum line in between the FPR and Plenum.
The hesitation im getting could possibly be the interference of two sources connected to the bov
will let ya know how it goes.
mate u will find that its a miss matched compressor/compressor wheel, i had the same thing with a gcg hiflow of an rb20 turbo which uses the same internals as the rb25/vg30 gcg highflow, i used to get to 5psi then off/on throttle then it would go to 10psi etc, bov would vent too even when turned hard as it could
i should of know better then to hiflow an rb20 turbo, oh well lesson learnt!
  • 4 weeks later...
nar not yet i should see if the bloke that i sold it to has witnessed it yet
i can give u a dyno sheet that shows how poor the boost is held
scott from insight in sydney who tuned my car said it is because of mismatched housings/wheel selection
this often happens with hiflows. if you are going to get one get one that has been researched and built for a specific application like a Slide hiflow or a GCG.
now it will prob cost twice as much to geo sorted :O
Check here
http://www.turbobygarrett.com/turbobygarre...bo_tech103.html
for the Garrett tutorial on what causes surge
So the question is
1. how did you decide on the specs for the high flow?
2. do you know what size/spec impellers have been used? (if so, post them up please)
Edited by Dale FZ1
Thats the turbo,
im not sure of teh specs of the wheels used, i bought the turbo off a mate
i will ask to see if he would know what size the wheels were
turbo australia did clean the wheels and rebalanced them
so hopefully they remember me and could tell
but i was thinking they would of seen then if it was a missmatch of wheel size for the r33 turbo etc.
Only problem i have is, it never did it at 12psi with my standard airbox still on.
i probably did say that earlier in the post but yeah not sure.
Yet when it wasnt doin it, i still had standard injectors,
time it did start doing this, was when i upgraded to metal induction pipe, z32afm, 555inj's and fuel reg.
and set on 18psi.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
