If thats what your using (pics) I can give some reasons for surge . The compressor looks like an old T04B 8/16 blade wheel which is really a low speed design . Some people try to use them in "Hi flows" and they generally surge because the turbine wants to drive them at a speed which pumps too much air at low engine speed hence the pressure waves and reversals at the spool phase . Judging by the wall thickness of the compressor housings inlet snout its probaby the -24 or -25 version of the 409179 series which is 70mm diametre T04B 8/16 blade compressors .
If you must persist with that thing (pic example) the easiest thing to do is to exchange the compressor wheel for one of the 6/12 blade T04B compressors which are 409826 series and are available in 39/48/57/62 and 70 trim . Depending on what 8 blade wheel it has one of the 6 blade compressors may go in with a little reprofiling of the compressor housing or get another and have it profiled to suit . This is just one option but something tested and proven would be better .
Cheers A .
what you have said makes alot of sense discopotato03
as when i ran the turbo at 12psi it wasnt really doing it, not pushing enough air for it to hesitate.
18psi just makes it goes nuts,
depending on how much changing the compressor wheel is and mucking round, might be better off buying a whole new turbo.
Even though 12psi didnt make it hesitate, i wasnt happy with the power it was making so will be pointless going back to it.
i'll let yas know what happens
basically pressure past the compressor outlet is going higher than the compressor can supply, so it surges.
a bit like trying to pedal on a bike down a hill, and gravity pulls you do so fast that you cant pedal quick enough, but with like foot brakes, so your feet are pulled along with the road drive
I tend to agree with Adrian's views about the number of blades affecting how effectively the impeller can push air at lower shaft speeds vs something similar with fewer blades. It could be something as simple as that - often it's not easy to get a spot-on spec when trying something new/different. Older designs shouldn't be dismissed outright just because they're older. They just need to be matched to the application.
320hp @ 16psi is nothing to sneeze at BTW - obviously it has the mumbo to support good power but not able to work across the range. Garrett's tutorials in living colour in your garage?? :)
If you want to know the spec of the impellers, I would recommend speaking with Ross or Josh at Turbo Aust. If they did the high flow job, it will be documented.
Do you know what sort of characteristics or power target your mate had when getting the specs finalised?
well on matty sprys dyno it had a recording of 300rwhp on 15psi i think
so fairly close to mine,
but it wasnt on his car for long as he put a gt3540 turbo on his car.
speaking to turbo australia was going to be last resort after fiddling around with harder springs for bov.
but after looking at recent posts, it could possibly be goin to first or 2nd option.
Only problem though, is the hiflow job was done by the company before they were known as turbo australia, forget what they were called. So having documents of the specs will be hopeless to find.
thanks for the info guys really appreicated, should be pretty much spot on with fixing this crap.
Don't understand why it would be a last resort?? Pick up the phone and talk to them. I can't comprehend how you are going to fix it without knowing what you have.
FWIW, Turbo Australia are a new company from scratch. Check their web page here
http://www.turboaustralia.com.au/downloads...aliaOpening.pdf
See how you go - best of luck! :P
  • 3 months later...
yeah i dont know what the problem was in the end cause i changed turbo, well still in the process of
i believe the reason of why it was not doing the surging at 12 but at 18psi, is that air was being pushed through the front of the turbo into the sensitive z32 afm
im pretty sure when i ran the turbo at 12psi, is that i still had a standard afm, which probably didnt pick up the air being pushed through as much.
things you could try, is putting a stronger spring in ya bov, putting a 90 degree bend in ya intake pipe so if air is being forced back through to the afm, it wont be as forceful??
or relocating your afm after the TPS, or run a aftermarket computer that doesnt require afm.
if you figure it out
please let us know
    • Ok, can confirm.  if you use it like a normal human being in the real world, it works fine.  it only starts crossing wires if I keep using the fob over and over again in a very short period. So if I just chill the f**k out, it works 😂😂
    • Im about to run a e30 mix of e85 and 98ron but i read that australian fuels specifically 98ron doesnt contain ethanol so on the calculator when it says pump ethanol percentage do i just put 0 or is this statement even true? And if it is true i assume i dont need to test any 98ron pumps.
    • So... the fob I had for my Skyline always had this issue where the "Unlock" button worked with no issues but the "Lock" button did nothing (and I always had to lock with the key) I thought I'd try resetting and pairing the key to the car today to see if that fixes the issue. I did the standard steps to program a key but realised my central locking was doing its own thing from time to time. 1st time: The driver-side doors would not lock or unlock when using the fob. No issues with the key. I figured it was the right time to change the battery in the fob so decided to go get one. When I went to the shop all doors locked and unlocked with the fob (while it had the old battery 🙃)   2nd time: When I locked the car, it would lock itself and immediately unlock. If I unlocked it, it would unlock and immediately lock.   3rd time:  After a bit of cursing and praying, that weird bug stopped. But then the rear passenger door started being a pain. It wouldn't really follow what the fob was asking it to do. Sometimes even using the key would not do what I wanted. So I'd lock the car with the key and all doors would lock, but the rear passenger lock didn't do anything at all. And then after a few moments, it would work again.   Is there a fuse that I should be looking at? or, is this one of those things where the door card needs to come off and some unit needs to be replaced? It just seems to happen from time to time and if I give her some space and come back later, there are no issues  🤦‍♂️ Also, should I try to program the fob again to the car just to see if that solves it?
    • One would assume a turbo is somewhere in its future down the line given they slap turbos on pretty much everything that arrives
    • I’m guess it’ll end up with a turbo
