hey guys,
was outside eating a pizza and decided to roll my VS-KFs over to the ceffy to have a look at what they'd look like on it. starting to get second thoughts about using them on an S14 :D
suits the colour really well i think.
car should be going really soon hopefully, new engine is built and alls thats left is to decide weather to keep the current Tsp kit or use my uras kit...im starting to lean towards the tsp kit as i havent seen another ceffy with this on yet in aust :)
https://www.sau.com.au/forums/topic/152294-some-inspiration-for-myself/
yeah dude, seriously man-up and stop listening to your girlfriend, you can't let her rule your life you gotta show her who's the boss..
put the damn wheels on hey, man up dude...
that's my advice
that's my advice
what the stock CA ones :P
vs-kfs are 18x10 and 18x11 -13, they where going to go on my next car (s14) and just get a random set of wheels for the ceffy, which will just be a pig slider. but we will see soon enough >_<
the mrs S13 convertible will be up for sale soon to fund the said project >_<
they dont fit as crazy as you'd think, on the S13 vert the 11s only sit outside the guards a couple of centimeteres (with a small overfender) so on say an S14 with large guards it should sit under. its the fronts im more worried about as the spokes just touch by about 1mm on the R32 type M brakes. i hope S14 is different
Some small slip on spacers will help over come any issues with brake clearance.. I'm running 5mm + 3mm spacers each side at the front with my 18x10 +8 Stiches.
Rears are 11 -1 with what I think are R33 hubs. Just to give you an idea on what guard mods you will need
Edited by Drift_Limo
not at home atm
but rears on my cef were 18x11 +0 on my efors... -2.5 deg camber and 225/40/18 stretched over the 11's... same overfender as drift limo's sat in about 15mm...
drift limo looks like running less camber thus fills out those guards
btw if you want a set i have some here... 400 bones n theyre yours
Is this car driving around yet?
A31cefiro - that's fat.. keep it.
drift_limo - that's also fat. Are they moulded flares or just really ambitious guard rolling?
Bolt on flares smoothed over..
No its still in deep hibernation... Sold the replacement 25DET a couple of weeks ago due to being poor arse hobo :laugh: It does run on, 4 cyls with a Wolf base tune. Not good for the wastegate though :P
omg drift limo, so sexy, wish i had that look.
Cheers for the kind words and huddy... Wolfwood yours has so much potential.. I like AVS's but could look soo f**king horn with mega lowering and some dish under those guards.
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
