sorry guys but i dont know where this thread belongs, im just curiouse is there one device that does them all because i really cant be stuffed fitting 20 different units in my car. I know most people like that look because it makes things look more hi tech or what ever, but personally i like neat. any idea's
  • Replies 60
1. You dont need a turbo timer, do a search, SydneyKid has already clearly outlined why.
2. You have only listed 3 things there, I fail to see where the other 17 units are..........?
3. I dont believe this unit you are after, the all-in-one, exists....?
Ha just what i like to see positive input with out sarcasm
absolute ledgend SKA
cheers AlexCim
Yeah I have a TT too, came with the car, used it for a while but now just set it to zero, still it shows my boost, albeit in bar, still it is a bit useless.
And I am not tottally against them, but if you read the following thread, you will see why I believe they are not worth buying.
http://www.skylinesaustralia.com/forums/in...t&p=2309803
No offence to anyone that has a TT, but they seem like RICE to me... Your car won't cool down sitting still while running, you need to drive it around slowly so the air flow can cool it. Ever noticed on a hot day that your car gets warmer sitting at the lights, then cools down once you start moving again?
That is the whole explanation (in a nut shell) to why they are not worth having. And that they are a great place for a car thief to hot wire the car from...
Cheers
Luke
All in one, no
but boost and engine management can be controlled in 1, PFC with BC kit. However...forget that idea.
Wolf ECU has a built in boost controller and possibly a turbo timer, also SK said to me he his first choice for EBC with a Power FC is the standard BC kit.
I think Alex is probably pointing to the Auto/no PFC issues there. It would be great to have the management know what the boost is doing, I think that would help a lot.
I guess we will all have to settle for "different strokes for different folks"
Absolutely! You want one, get one, just stating why I wouldn't have one. Freedom of information, all good.
Cheers
Luke
cheers darrinspencer
did a bit of poken around on the wolf v500
http://wolfems.cart.net.au/details/635751.html
but half way down the page is says "Turbo Timer support "
does that mean it supports "your" current turbo or that its built in?
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
