Eoi: Wrecking R32 Gts-t 4door Manual
By Red Sky II · Posted
Hi I am looking at doing the same so was wondering whether you went ahead with the replacement. If so, who did you use, what fascia kit did you get and approximately how much did it cost? Cheers -
I can't edit my original post, but I've updated my tables to be split into two as it was getting a bit OTT having a single huge list. This now includes Turbosmart turbos - the first list is "entry level", or up to 68mm. The second is "for those who like to party" and starts at 62mm.
Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
Got any pics of the carpet fitted?
When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
