would the n1 headlights for the r32 have the same wiring as the normal r32?
has anyone tried this?
I can't confirm - so a bit useless really, but I would imagine it's exactly the same plug. If it isn't it'd be a relatively easy re-wire. If I had to bet my money would be on the same plug (knowing Nissan of the era).
whats the difference between the n1 headlight and standard gtst headlights?
N1 lights look aggressive as all hell. My dream r32 wouldn't be complete without them, they have a squarer looking section, kind of like the difference between Aus spec r31 lights and JDM r31 projector lights.
https://www.sau.com.au/forums/topic/152402-n1-headlgihts/#findComment-2835732
n1 use h4 as the main headlight...whilst the stock ones use i think h1 or h3 cant rem. As with wiring from memory....might have to change to H4 plug. Can check if your really desparte to know. pm me
when you unplug the H3C light, dont unplug it from the globe. There is another plug that leads to the highbeams so both low and high beams share the same plug leading to the main loom. So unplug it from there...its considerably bigger. You end up using that bigger plug to connect to the hi/low H4 in the N1 headlight. Parkers use the same plug. And then there is that extra plug that will be tucked away (somewhere towards the grill). It wont be plugged into anything, and thats the one you will use for the fog/driving lights
Edited by [WLDCRD]
https://www.sau.com.au/forums/topic/152402-n1-headlgihts/#findComment-2837739
far out, here i was thinking.......the above pic was GTR headlights, and the bottom pic was standard GTST, i had both on my 32, wired exactly the same, i just plugged em in, got some really bright white H4 lamps and bingo, she work and light street
https://www.sau.com.au/forums/topic/152402-n1-headlgihts/#findComment-2838076
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
