hey all, weird sale, but i have $225 at alljap wreckers at nerang on the gold coast, i have it left over after i rebuilt stuff on my car to bring it to a newer look..
alljap was the main place i could find parts for a skyline, and no other places had any series 2 parts, but these guys did.. main point.. if any one needs any parts, let me know, and ill ring them and get it down from there wharehouse in brisbane if its not at there nerang wharehouse... would rather have someone spend the whole credit, and if they do, ill sell them the part cheap. eg: $225 for the part, ill sell it to you for $160 thats $75 off.. any takers for parts?
Edited by seriesII
https://www.sau.com.au/forums/topic/152435-alljap-wreckers-credit/
should be at nerang.. goood place, best ive seen off, had alot more then rollins for sure... haha, is weird sale.. hah, but, good if ya need something stock for your car?, and saving some cash?, ill find out any parts, and they test there parts before they buy them, or take them of a car..
Alljap Auto Parts
9 Hilldon Crt Nerang QLD 4211
ph: (07) 5596 0485 Auto Parts Recyclers
hey, yup, thats right.. that would be even beta if you called hey.. much easier.. ).. let me know. yeah... $250 and you only pay $160.. keep me posted and ill pick it up and pay for it, or how ever you wanna do it.. i dont mind the drive :D..
or, if you need a part thats $300, ill do the $225 and you pay the difference, and ill only charge the $160 and the guy at the store will charge you any extra the part was..
eg: $300 part.. ill pay $225, and you pay $235 all up for your $300 part.. ill just meet who ever there at any time, i work for my self, so i can take a break when ever :)
Edited by seriesII
I'm chasing an engine mount front left for a CA18DE S13 Silvia and also an a/c compressor for the same car. Asian Auto spares quoted me $75 for the mount and $50 for the compressor which comes to $125. Let me know how much you can get them for.
Thanks!
hhehe, $85, cause ill drive there and get the part , its like $7 of fuel for me there and back :)and to drop[ it some were near you.. unless you wanna meet me there?.. $80 if you meet me at alljap :")
u knw if they have any CA18DET running engines and looms up at nerang?
hey, not that i have ever seen of in there, just looks like a huge wharehouse with parts in sections. maby try rma at southport?, they have full cars there, if ya lucky, walk in, get him to start it when the cars up and pick your part :laugh: .. only place i seen that has done that for me so far :P..hope it helped
so alljap has no engines..? the underwood one does.. oh well. ill let u knw mate. but im in need of a working CA18DET and ECU.. :) if u can help that will be great >_<
ohh hey, sorry, im sure they have full working engines.. sorry, i thought you meant, working, as the motor is there and can start up for you live (in a car or what ever) haha.. i would say full engines and any parts like that would be no prob.. im getting a few parts at the moment for a guy on here so ill see how much credit is left and see what i can get for you...
Thanks!
hey, got the engine mount, ill meet you around the spit on sunday.. parts in good condition, bit oily, but thats a good thing :)
haha.. so they cant start it up for me...? :) they got compression tests on the engines?
let me knw what u find. even if u got only a bit of credit left im still interested..
thanks
mark.
  • 2 months later...
    • All the schemas I can see, indicate your typical setup of ATF 'cooler' (read: heat exchanger) in the bottom radiator tank..ie; https://nissan.epc-data.com/stagea/wgnc34/5413-rb25det/engine/214/ ...but I can prattle on a bit here. These trannies have a thermistor in the sump ~ the TCU reads this and 1. bumps the line pressure up when the ATF is 'cold' and 2. prevents the TC lockup clutch from operating, until the ATF comes up to minimum operating temp (keeps the ATF 'churning' through the TC so it heats up quicker) -- trigger point is around 55C. In these conditions, the engine coolant temperature rises faster than the ATF temperature, and also helps heat the ATF up, which is why it's best to think of the in radiator tank setup as a heat exchanger ; the heat can flow in both directions... ...with these trannies, the 'hot' ATF comes out the front banjo bolt, flows through the cooler/heat exchanger, and returns to the box  via the rear banjo bolt. This gets a mention, due to the wildly different opinions wrt running auto trans fluid coolers ~ do you bypass the in radiator tank altogether, or put the cooler inline with the in radiator tank system...and then, do you put the additional cooler before of after the in radiator tank system?... ....fact is the nominal engine operating temp (roughly 75C), happens to be the ideal temperature for the ATF used in these trannies as well (no surprises there), so for the in radiator tank system to actually 'cool' the ATF, the ATF temp has to be hotter than that...lets say 100C -- you've got 25C of 'excess' heat, (slowly) pumping into the 75C coolant. This part of the equation changes drastically, when you've got 100C ATF flowing through an air cooled radiator ; you can move a lot more excess heat, faster ~ it is possible to cool the ATF 'too much' as it were...(climate matters a lot)... ...in an 'ideal' setup, what you're really trying to control here, is flash heating of the ATF, primarily produced by the TC interface. In a perfect world, wrt auto trans oil cooling, you want a dedicated trans cooler with builtin thermostatic valving - they exist. These should be run inline and before the in radiator tank system ~ when 'cold' the valving bypasses the fin stack, allowing the ATF to flow direct to the in radiator tank heat exchanger, so it works 'as intended' with helping heat the ATF up. When 'hot' (iirc it was 50C threshold), the valving shuts forcing the ATF through the cooler fin stack, and onto the in radiator tank heat exchanger...and you sort of think of it as a 'thermal conditioner' of sorts...ie; if you did cool your ATF down to 65C, the coolant will add a little heat, otherwise it works as intended... ...the 'hot' ATF coming from the front bango bolt, is instantiated from the TC when in use, so all/any flash heated oil, flows to the fluid-to-air cooler first, and because of the greater heat differential, you can get rid of this heat fast. Just how big (BTU/h) this cooler needs to be to effectively dissipate this TC flash heat, is the charm...too many variables to discuss here, but I just wanted to point out the nitty-gritty of automatic trans fluid coolers ~ they're a different beastie to what most ppl think of when considering an 'oil cooler'... /3.5cents
    • Been a busy but productive day. Axle and hubs acquired. All fitted up after a bit of modifying. Need to sort out wider mudguards and running light reflector covers but other than that the trailer is gooood to go !!
    • Selling a SMIC for a Nissan Stagea C34 Series 2 and the pipe from the intercooler to inlet. (I believe it is the same R34 GTT, please correct me if I'm wrong) Price: $50? I dont have a photo of the big black pipe that goes from SMIC outlet to throttle body.
    • So the original radiator is leaking now. Looking at getting a fully aluminium one next. Am I correct in saying that the Series 2 Auto Stageas have a separate trans cooler from factory (located in between the rad and intercooler in my previous post/message).   Currently looking at Fenix $460, Blitz $700, GReddy $800, and KoyoRad $740. What are everyones thought on Fenix ( ive read a few comments saying theyre cheap Chinese rebrands etc and how their build quality is... well.. chinese...)  compared to the others? Worth the extra couple hundies?
