Dear all,
Anyone know what the strut bolt torque spec (how much I should torque it when screwing it back in)?
(the one you take off to install a strut brace?)
I've been trying to find the information before I unbolt/unscrew it.
These ones:
Thank you.
https://www.sau.com.au/forums/topic/152453-strut-bolt-torque-spec/
If you snap that bolt using a spanner, you must be a muscle man.
Just use a spanner of the correct size - 13mm from memroy, do it tight with the spanner, and you'll be right. Just be sensible. Like do it tight with the 13 mm, not f**k off tight.
You'll have a problem overtorquing if say you used a breaker bar or something, but generally, you'll be fine.
The tps bolts are different - they're a small bolt.
Okay, I've done it for 35 ft-lb with a torque wrench, should be good.
Took two and a half hours to install the engine damper, that engine lift plate (whatever it is called) bolts are hard to unscrew and tighten, trying not to disconnect anything.
i snapped the rear strut bolt when tightening it after installing my rear strut brace.. so its not unheard of
costly exercise to source a new strut top asap to get the car back on the road...
Waz, how tight did you do it? Like just reasonable? Or crazy tight?
What did you use to tighten it? a spanner? or a breaker bar?
I've found, after a while, you get the hang of how tight certain things should be. If you use a spanner, you can actually tighten it to within the torque spec. It's hard to describe, but you get the hang of it after you do it many times.
yeah i was doing it pretty tight but that wasn't the problem really
because it was a rear brace i was in the boot trying to use a spanner and ended up resorting to a ratchet but there's not much room to move the handle in there
and the problem came when i not only was trying to tighten it but was off balance and introduced some angle on the handle of the wrench causing the bolt to shear off!
my bad.. you learn form mistakes better than anything
  • 1 year later...
did this just before....however i induced no angle into it, and the bolt appears to have a failure caused by torsion shear (twisting shear in the plane of the thread). It was simply replacing the stock lock nuts, and was barely even tight which leads me to believe it was caused due to over tightening previously and this exercise threw it over the edge.
Anybody got any tricks to get her quickly back on the road?
    • Update time!  The JZX110 had some maintenance needing to be done, so a lot of the seals with replaced to fix some oil leaks. Also used this opportunity to whack on a front mount that I'd bought some time ago.  I also finally got the rear lip painted and fitted.  I then got the exhaust done. It's just a catback for now. Custom made 3" stainless with a turn down. I could have a tip coming out, but it will require cutting the rear lip and possibly the bumper itself. So far I do like and it's made the car a little more zippy.  Close out with some nice pictures of the cars and a sneak peek of what's next.
    • Once you learn it all, you find you do the job once. But this is the best way to learn, as you won't forget the lessons
    • Edit: It's now known as "R Performance" and is still in operation.
    • This lady loved her FD for 25 years!  https://www.topspeed.com/80-year-old-woman-donates-fd-rx-7-mazda/ My brother in law. He's nice enough to let me drive it whenever. He'll likely not see this, but I'll try: @r-is-for-fun got any pics?
    • Just something I found searching for more info on Emotion R, apparently the ECR33 Skyline GTS25t was either originally black, or there were two of them, the black one being the original demo car, then building a white one which was part of the 1997-onwards (to at least 2008!) Cockpit Tatebayashi Tokyo Auto Salon booth demo cars. It appears that Emotion R closed down in 2008 and was declared bankrupt in 2010: http://bank-db.com/hasan/208365. Scan of a magazine with the black R33 from 1996: Wayback machine archived page from May, 2000: https://web.archive.org/web/20000529061027/http://www.emotion-r.co.jp/skyline.html Option magazine with a few photos from the Cockpit Tatebayashi booth at the Auto Salon from various years: 2002: http://www.jdm-option.com/photo/index.php?action=item&category_id=154&image_id=3507 2003: http://www.jdm-option.com/photo/index.php?action=item&category_id=137&image_id=3033 2005: http://www.jdm-option.com/photo/index.php?action=item&category_id=116&image_id=1831 In 2008 Cusco website mentions that the Cockpit Tatebayashi ECR33 was displayed at that year's Tokyo Auto Salon: https://www.cusco.co.jp/event/2008/12/post_735.html As of 2021 it appears that the ECR33 demo car ended up being exported to Florida, USA: https://rmcmiami.com/inventory/1996-nissan-skyline-r33-cockpit-tatebayashi-demo-car-big-te06-turbo-endless-brakes-lsd-450hp/ And finally here's Google streetview of the Emorion R garage in 2023 which is amazingly not only still there, but the showroom is still full of various parts in stock and funishings, etc.: https://maps.app.goo.gl/ttyEAZdZLyzermyT9 Apologies for nerding out a bit. I used to love doing this 20 years ago on SAU and got a bit nostalgic for a moment... 😅
