Hi im planning on moving from nz to WA in march and i have my eye on a few skylines as i work in a car shop over here im planning to purchase some stuff here to bring over,
I have my eye on a SSQ Bov and i was wondering do i need this type
28967642_full.jpg this has a 32mm flange adaptor
or do i need this style
with a weld on flange
the skyline im thinking of getting is a series 2 r33 with a rb25det and help would be much appreciated
https://www.sau.com.au/forums/topic/152481-hks-ssq-bov/
dude definately atmo have one on ma 34 sounds sweet but muddles with the AFM so here's the solution
>_<
i'm from WA not sure where i can get them from so still snoopin around tyrin to find it
http://www.horsepowerfreaks.com/sale/HKS/B..._Kits/part/SSQV
hope this helps ya out
https://www.sau.com.au/forums/topic/152481-hks-ssq-bov/#findComment-2837560
I've got a HKS SSQV its atmo but you can get a plumb adapter for it very simple to install, just unbolt 4 allen bolts take out the thin and put the plumb back adapter in place, if people are interested i will take pics as i'm considering selling mine because i've replaced it with a simple yet cost effective gtr bov for my rb25det
https://www.sau.com.au/forums/topic/152481-hks-ssq-bov/#findComment-2837596
does a gtr bov bolt straight up to the rb25det?
Reason i ask is because i wanna boost my car but the factory gtst bov leaks at around 10 psi, so a gtr bov would be a good solution for me as it would look stock and hold boost?
can anyone confirm?
https://www.sau.com.au/forums/topic/152481-hks-ssq-bov/#findComment-2838530
Gtr bov bolts straight up to the factory rb25 bov position BUT the rubber hose/return pipe for the plumb back is different size. GTR has bigger return pipe over the RB25 bov, but you can easily modify or get a replacement hose for it to fit.
If your Rb25 bov leaks replace it with a GTR bov or aftermarket plumb back. A simple a dyno/power run with the power against the boost, if the boost appears unstable = sign of leakage.
I can't compare the std RB25 bov to the GTR one because i've recently switch from a HKS ssqv atmo to GTR bov for my new setup.
https://www.sau.com.au/forums/topic/152481-hks-ssq-bov/#findComment-2838805
Where did u buy the plumb back adapter from?
Post some picks up please?
cheers
https://www.sau.com.au/forums/topic/152481-hks-ssq-bov/#findComment-2840100
Is this the type of BOV that makes the bird "tweet" at gear change and is the spring adjustable so you can get a good flutter(dose..lol) at say 10 psi?
Yer thats the one but i think the cheapo monza one has that lil screw thing on the back the HKS one doesnt have the adjust thing
https://www.sau.com.au/forums/topic/152481-hks-ssq-bov/#findComment-2840205
hey morgan check here
http://www.blowoffvalves.com/
got one on ma 34 sounds awesome n i haven't had stallin issues or anything
been great to me :laugh: but it does play around with ur afm
Sweet as :D Thanks for the link.
I bought a new fin for it, will this change the sound more?
https://www.sau.com.au/forums/topic/152481-hks-ssq-bov/#findComment-2840905
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
    • Set of knee pads for a R34. Will fit every model I think. Comes with everything except the rubber covers for the bolt holes. Still in great condition. You will need to drill holes to mount these or use double sided tape. I can do free shipping and will be shipping from the Netherlands with tracking.
