ONROADS Dyno day - Hosted by Dr Drift
To celebrate the launch of Onroads.com.au we will be having our very own Dyno Day hosted by our very own Dr Drift.
Sunday 4th March 2007
Venue:
Dr Drift
Unit 5 / 9 Alick Rd
Brooklyn, Victoria
Australia, 3012
Price $40/car includes power run and print out (FWD and RWD cars only)
Prizes
Trophy for the most powerful forced induction vehicle - per litre. (turbo/super charged)
Trophy for the most powerful naturally aspirated vehicle - per litre.
Doing it per litre puts everyone on a level playing field, A 4cyl can potentially win over a V8. :lol:
but as danoz always said THERE'S STILL MORE.
EVERY 3 days from now we will be giving away one free dyno run for the dyno day to one of our members.
How do I win?
From now up until the dyno day members will receive points for signing up, posting and referrals.
10 points - Signing Up
15 points - Making a referral (this can be done in your MYONROADS menu)
10 points - Making a post in the forum
20 points - Making a Post in the PARTS section
Simple, the more points you have the more chance you have of winning a free dyno run at our dyno day!
To secure your spot at the dyno day PM me for payment details. Full Payment must be made prior. Limited spots available. Spectators welcome.
Edited by jungle_s14a
https://www.sau.com.au/forums/topic/152489-dyno-day-onroads-march-4th/
Good to see more of you coming on board.
Anyone who is wanting to come, you will need to pay the $40 up front to secure your spot. We are filling up quickly.
To secure a spot you can email me for payment details at: [email protected], you can also PM me through onroads.
thanks,
David
what time does it start? i start work at 1:30pm on sunday's...
and what are the suburbs around brooklyn? have no idea where that is... besides the new york suburb...
um, Tottenham, West Footscray & Yarraville and maybe altona north?
  • 4 weeks later...
Just over the Westgate Fwy, take Millers Road exit at Altona and a right at the bottom of the ramp. Heads towards the Old Geelong Road, Princes Hwy. That is Brooklyn area. We have a depot there that I frequent.
Sorry to hear about the dyno, not good :D
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
