Hi all,
I have the following for sale. Been adding bits and pieces to her but have to give up as i have to leave for O/S soon.
Some details bout the car.
65k on the millage
White R33 Gtst Series 2.
Rare Impul kit.
Nismo Rims.
Genuine Hybrid intercooler
Greddy boost controller
Trust BOV
Apexi Pod with cool air intake
Front cusco strut bar
Falken Azenis RT615 with decent threads
Bosch 040 fuel pump
Power FC with controller tuned to 200 kws
As can be seen the car is ready for a turbo upgarde with mostly if not all first stages mods all done up. I could pull everything apart to sell but i believe she is properly done up so i believe you would think so too.
Call to arrange to view. 0413279780
PRICE: $19000 (Neg.)
Price DROPPED !!! $17000
Edited by Kahleong
https://www.sau.com.au/forums/topic/152554-97-r33-gtst-for-sale-sydney-17000/
  • 1 month later...
GUYS !!!
Back from O/S to settle some stuff and sell this car before it goes to my fren. Need to sell it before I leave for another 6 mths. Price DROPPED TO 17000. Pls call to arrange. Will be in aus from tom.
CHeers
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
