  • Replies 62
Other parts will be added tonite but for now just ask me what ive got as ive got heaps of parts laying around and ill see if i got it
Nick
HEY nick how about a anti rattle spring for front brake calipers need one only ,would you have one Drew
hey andrew got a pic not sure what u mean...but i will most likely have it
Prob get one tomorrow ,its a piece of thin metal that goes from pad to pad on the caliper so to speak its probably high tensile but will post you a pic tomrrow of what it looks like in place
hi there...
im interested in the following
- standard suspension - $40
- brake master cylinder and brake booster x 2 - $80 each
- pair of front seats for r32 cloth material gc - $80
- r32 automatic transmission, was shifting fine when took out to convert to manual - $50
does the transmission have a computer to control it? im unfamiliar with R32...
Hey if anyone has pmd me since the server update, my pms have been playing up so ull need to wait a few days before i can reply, if its urgent pm ur number and ill call u about it.
K.O.S.W yes i have the weathershield LHS onlt though...but not sure bout postage as its kinda big and fragile
Nick
    • Great to hear you are bringing it out of the shed again. Unless you have specific issues I'd just add the wideband, get a good tune and enjoy it. Certainly no point changing coils etc if they are working. If would add fuel pressure and e85 sensor if you are doing a general update but not if it runs OK and you are just getting it back on track. The other thing is smaller, modern twins, -5 are OK for motorsport but pretty laggy and old tech for street use (of course, if performance is the priority a modern single with twin scroll manifold etc is the go but not cheap). The final thing worth considering is switching to an ethrottle if drivability is still an issue, it should make things a lot simpler and smoother
    • Yeah pretty sure they are m4, but best to check, and perhaps use new hardware Also don't over torque them......there was that one time I lost an expensive engine after a workshop overtorqued one of those bolts and it ended up in the oil pump (no, I don't know why they removed the intake mesh either)
    • I might have to shoot them an email. Pity the exchange rate is so bad at the moment. BTW, thanks for posting that table makes interesting reading.
    • Add these Sensors -Wideband, Oil Pressure, Fuel pressure, Intake air temp Good inspection of ignition system of coils, plugs and loom (12v feed and good ground)- a r35 kit is best bang for buck upgrade. A decent tuner should be able to see any issues with the trigger system- a link has good filtering but a good simple upgrade is the nz wiring bolt in kit. Check and replace all the fuel filters- you would be surprised at intank filter after a few years. Also good to check for any leaks on vac hoses and pipe work as has been said. No need to go overboard and spend big $$$ to enjoy the car. A quality tuner is getting harder to find as anyone with a laptop thinks they are a tuner. A link has great features to check sensor voltages and frequency inputs and easy to see live by pressing f12. The link can do a TPS & RPM fuel/ignition mapping on ITB cars then add a 4D table with MAP and ability to add a 5D to it (can help with economy at cruise with wheel speed vs TPS) Where are you located as that will help narrow down a good tuner ?
    • Reviving an old thread, I reckon my stagea is starting to slip. Car usually gets parked on a hill, narrow driveway so cant go up the driveway smoothly, anyhows, lately first gear feels "sluggish"? Not responsive. Feels like I gotta run the engine more than usual to get off the line...  Any recommendations for transmission servicing in Sydney? Or possibly just an excuse to go manual ?
