R32 GTS-t 4dr Type-M
RB20DET
Bought the car dead stock with 25,000kms on the clock. I didn't believe it was genuine so ripped water pump and timing belt out straight away and they were like new. Everything in the car was immaculate and still had new car smell! So I sorta believe the Kms a bit.
Originally an auto, but manual conversion done in Japan. Got it and started with the mods. Tried a few different coilovers (including Tein, Tanabe, Cusco and HSD) in the car until arriving at the current set up.
Had the car for 1 month before it out was out at the track. Other mods followed as required (really should've done diff MUCH earlier, but ohwell).
Blew the old RB20 (spun bottom end bearings) back in July 07, so then began looking for a new motor, was going to do RB25, but then found an RB30 cheap :)
Engine mods: RB25/30 with stock internals, upgraded valve springs, RB25 turbo oil pump, GTR injectors, Z32 AFM, Apexi pod, 3" turbo back HKS Super Drager exhaust, Blitz DSBC Spec-R, and FMIC. Running RB25 turbo with VG30 rear housing.
Suspension: Bilstein coilvers (Eibach springs 7/5 kg/mm), Whiteline adjustable swaybars 27/24mm, Tein castor rods, Adjustable front upper arms, Whiteline adjustable rear camber bushes (in traction rod) D-project rear upper arms, Apexi front strut brace, Uras tie rod spacers, alloy cradle bushes and HICAS lockbar.
Driveline: Kaaz 1.5way, Exedy Sports Ceramic 3 puck, RB25 gearbox
Other: Bride Zeta, Work Equip 17x9+20, 235/45R17 Proxes T1Rs, or 235/45R17 RE55S for circuit.
Waiting on new rims from Japan (P1 Buddys 17x9 +17)
VERY happy with the car, especially the suspension. Was aimed more at circuit racing as I wanted it to grip like a circuit car, and then make that slide. Handles MUCH better with the Bilsteins than any of the other rubbish coilovers I've had before.
Still a daily driver, does its job well
RB30DETboost.jpgNew RB30DET
RB30DETvsRB20DET.jpgRB30DET (black) vs RB20DET with GCG highflow (red)
Couple of vids from 07 G1 Round 1
- Thanks to Ryan (5LEEPER) for the footage
Last run is by far the best :/
Edited by salad
  • 1 month later...
  • Replies 57
It's got GTR front bar and Nissan skirts on it now, looks a lot better. Will try and get some new pics of it up soon I guess. Just lazy :(
Got some vid of the last comp, but yeah, that's about it, still waitin on pics...
  • 5 weeks later...
Couple of pics from last Satdee's drift prac with the GTR bar and Nissan 4dr skirts, and without the wing.
Avatar.jpgDriving straight at a drift practice!? ;)
6.jpg<--- Awful line... :wave:
Looks much tougher now
On the hunt for 4dr rear pods now! Preferably silver :laugh:
*Looks at andylaurel*:laugh:
Edited by salad
A few pics from SD round just gone.
Car's still goin well, heaps of grip (when the tyres aren't overheated) just need to get some more power now! Only running on 0.9bar on the track cos I dont wanna lose the rear wheel :blink: So less than 180rwkw :banana:
And decent tyres on the rear would be nice, ones that can take the heat of more than 4 laps... :P
Edited by salad
Just factory Nissan skirts. Like the GTR and type M for the 2door.
Was chasing them for ages, didn't want a big kit, just a factory looking sorta thing. I'm happy with the way it's turned out :)
Nice 4 door! very similar mods to mine, right down to the wheels :thanks: except i have a high flow neo turbo im about to bolt on and hope its not going to be too laggy :D
How much extra lock did you get with the spacers? very noticable?
I saw someone with a highflow NEO turbo change to a HKS GT-RS and made more power everywhere. The problem is the rear housing is too big on the NEO turbo and the lil RB20 struggles to spool it early. If you can, see if you can get the R33 rear housing on there. Machined out first of course
The spacers give you a fair bit more lock so they're definitely worth it. Also makes U-turns a lot easier :laugh:
Last run is by far the best ;)
Thanks to Ryan (5LEEPER) for the footage :)
Edited by salad
  • 1 month later...
Threw GTR injectors and RB25 GCG highflow on over the last couple of days. Got it tuned again and pulled 220rwkw on 1.4 bar with really good response for an RB20. 1.4 bar comes at 3600rpm :) Start making more power than the stock RB25 turbo at just before that too.
Will chuck up a dyno sheet soon.
Should make the drift practice tomorrow more interesting with another 50rwkw :) (I used to turn boost down on the track)
Dunno how the 2 year old organic clutch will do though :D
Edited by salad
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
