Hey,
Doing some research on amp wiring as I plan on installing the wiring to my temp amp. If im going to put in the wiring may as well set it all up for any future added amps.
Currently i have:
Aerpro 8gauge 4ch 600w amp wiring kit
Audioline 4x 75w RMS amplifier.
I find it hard to believe that the amp is 75w RMS, but thats what it states on the box...
Im planning on connecting 4 speakers to 1 amp and then buying a mono amp + sub.
My question are:
Will the 8gauge power cable provide enough power for both amplifiers?
Estimating that max 50w RMS per speaker (on the 4ch amp) and probably a 300-400w RMS 12inch sub.
How do i split the power for both amps? I read something about a distributor block?
Can the R32 alternator provide enough current for both amplifiers running on normal volume?
The 600w on the amp wiring kit refers to the max power the power cable can provide? Also the wiring kit has a 60amp fuse, will this need to be changed too?
Thanks for the help!
- Patrick
https://www.sau.com.au/forums/topic/152615-amp-wiring/
Alternator will be fine. If you're having issues improve your grounding (eg battery negative to chassis, amp to chassis, etc)
Power runs: Either a single run from battery positive to boot, and then use a distributor block (it's like a splitter) to separate into each amp, or you can make separate runs from battery to each amp. Remember to add a fuse within 30cm of the battery however.
https://www.sau.com.au/forums/topic/152615-amp-wiring/#findComment-2838972
see inserted comments.
Hey,
good idea.
Currently i have:
thats a start. kit is good for that amp.
My question are:
no. it will be enough for the 4ch you have only. if you are doing two I would suggest 4 awg and a 4-8awg distro block at the other end
correct.
it can. when you start getting REALLY big then is becomes a concern.
how big is the fuse(s) on the current 4ch that is there. if they are BELOW the 60A rating leave it be.
- Patrick
no probs. send cheque to address in sig :/
https://www.sau.com.au/forums/topic/152615-amp-wiring/#findComment-2838974
8 gauge will do the job, if the battery is in the boot, but I would probably use 4 gauge for power and earth cables just to be safe, only if you do go the additional mono block amp. If its just the 4 channel amp 8 gauge will be sweet.
If you need to split the cables you can use a distributer block such as in the link:
http://images.google.com.au/images?sourcei...sa=N&tab=wi
This basically makes the cable go in as one 8 or 4 gauge and then spits out as many 8 gauge cables as you need (1 for each amp). These have fuses in them also, but you should still have a fuse near the battery.
You can use one 60 amp fuse, place closed the battery, the cable from the battery to the fuse shouldn't be longer then about 30cm (so Ive been told by many) otherwise it wount protect your equipment as well. If you start blowing the 60 amp fuses easily when you turn it up a bit, go for an 80 amp, and it should be all good. This will all depend on how much power your amps have.
Just make sure you have really good grounding points. This can make or break your system!
https://www.sau.com.au/forums/topic/152615-amp-wiring/#findComment-2838984
Thanks all for the quick responses. Appreciate it!
Chris, the cheque is on the way :)
Time to buy another pair of rca cable, 4gauge power and a distru block.
Now what to do with this 6metre 8ga power cable...
Guess it can be cut in half and go from distru to both amps.
Thanks all :/
https://www.sau.com.au/forums/topic/152615-amp-wiring/#findComment-2839000
possibly. easier though to run it inside the drivers guard and through the main grommet there.
trying to install the amp wiring kit as i post this :pwned:
On a previous thread you posted for a r34:
put the wheel on full lock and peel the inner guard out. that will invlove removing the mud flap and a few screws above it. it will reveal a grommet about the size of a fist.
Is it the same for the R32?
Thanks :O
https://www.sau.com.au/forums/topic/152615-amp-wiring/#findComment-2857303
trying to install the amp wiring kit as i post this :P
Pull that inner guard out and all will be revealed, including a big grommet
https://www.sau.com.au/forums/topic/152615-amp-wiring/#findComment-2857309
Just popped off the inner guard to reveal a large rubber grommet blocking my hole :P
Do i pop it out or do i make a hole through it? not sure how to get thruugh this thick rubber...
Edit: Made a hole using screwdriver :) the power cable is finally through ^^,
https://www.sau.com.au/forums/topic/152615-amp-wiring/#findComment-2857378
  • 11 months later...
i'm in need of choosing a 4 channel amplifier and speaker cables.
is there any rule of thumb in terms of determining which gauge wire to use for the speaker/amp combo? (i.e. is it dependent on RMS or MAX?) been doing some research on gauges, impedance, ohms, amps, fuses, etc. and the Aeropro 4 channel kits seem to be what i'm after.
a run down on my current setup.
  • deh p4650mp (has only 1 rca pre-out. should i upgrade to maximize my 4 channel potential?)
  • 35W RMS 4ohms (220W MAX) fronts 6"
  • 40W RMS 4ohms (260W MAX) rear 6x9"
  • would i select for amp rms to match speaker rms (at matching ohms?)
few points i need clarification on.
  • the smaller the number (gauge wise) the thicker the wire and the higher the resistance. correct?
  • you would want to use the thinnest cable suited for your system's power. correct
comparing the 8ga and 6ga Aeropro kits
  • why is the trigger/remote cable & speaker cable thicker in the kit with the thinner power wire?
  • which of the two kits would suit me best, i'm guessing the 8 Ga.? i have no intention of upgrading nor do i want a sub
    Aeropro 4 Channel Amplifier Wiring Kit, 600 Watt 6 Ga.
    Kit contains:
    - 6M 6GA Clear Red Power Cable, 195 x 7 x 0.12mm, O.D. 8mm
    - 1.2M 6GA Clear Black Ground Cable, 195 x 7 x 0.12mm, O.D. 8mm
    - 5.5M 18GA Blue Trigger Wire , 16 x 0.25mm O.D. 2.4mm
    - 5M Clear Blue Double Shield RCA Cable, O.D. 9mm, 4 Plugs to 4 Right Angled Plugs
    - 10M 14GA Clear Speaker Cable,(182 x 0.12mm) x 2, O.D. 3.8 x 7.6mm
    - 1 Silver plated 4/8GA Fuse Holder (PS43) including 50 Amp Fuse
    - 4 Gold Ring Terminal, 8.3 x 7mm
    - 2 Gold Space Terminals, 5.3 x 3.8mm
    - 4 x 14/18GA Butt Connectors
    - 2 x 16/22GA Butt Connectors
    - 4 x 16/18GA GOld Speaker Female Terminals
    - 5 x 16/18GA GOld Spade Terminals 4.2 x 2.8mm
    Aeropro 4 Channel Amplifier Wiring Kit, 600 Watt 8 Ga.
    kit contains:
    - 6M 8GA Red Power Cable
    - 1.2M 8GA Black Ground Cable
    - 6M 16GA Blue Trigger Cable
    - 2 x 6 metre Twisted Pair RCA Leads with Right Angled Plugs on one end
    - 6M 12GA Speaker Cable
    - inline AGU Fuse Holder wirh 60 Amp AGU Fuse
cheers
eug
https://www.sau.com.au/forums/topic/152615-amp-wiring/#findComment-3604949
if all you are doing is a small 4 ch then the 8awg kit will do fine. the 6 awg kit will have more speaker wire in it though.
as for AWG structure:
lower number = bigger cable = less resistance ( you had 'more' in your points)
for power that works well. for speakers - anything over under 16awg (numerically) to me is overkill.
questions - ask/ring me >_<
https://www.sau.com.au/forums/topic/152615-amp-wiring/#findComment-3605134
    • Hey guys I’m chasing a Rb20det complete or bare block need a good running engine as mine has low comp
    • You're making my point for me. 95 is not "premium". It is a "slightly higher octane" version of the basic 91 product. The premium product that they want people to buy (for all the venal corporate reasons of making more profit, and all the possibly specious reasons of it being a "better" fuel with nicer additive packages) is the 98 octane stuff. 95 is the classic middle child. No-one wants it. No-one cares about it. It is just there, occupying a space in the product hierarchy.
    • 98 and 95 have to meet the same national fuel standards beside the actual RON.  91 has lower standards (which are quite poor really), so 95 is certainly not 91 with some octane booster. It would be an easier argument to claim 98 is just 95 with some octane boosters. Also RON doesn't specify 'quality' in any sense, only the octane number.  Anything different retailers decide or not decide to add to their 95 or 98 is arbitrary and not defined by the RON figure.
    • Anyone know alternatives to powerplus tungsten? Can't find an alternative online.
    • 95 is just a scam outright. 98 is the real "premium" with all the best detergents and other additive packages, and at least historically, used to be more dense also. 95 is just 91 bargain basement shit with a little extra octane rating. Of course, there's 91 and there's 91 also. I always (back in the 90s early 2000s) refused to put fuel in from supermarket related fuel chains on the basis that it was nasty half arsed shit imported from Indonesia. Nowadays, I suspect that there is little difference between the nasty half-arsed shit brought in by the "bargain" chains and the nasty half-arsed shit brought in by the big brands, given that most of it is coming from the same SEAsian refineries. Anyway - if there's still anything to that logic, then it would apply to 95 also. 98 is only made in decent refineries and, as I said, is usually the "premium" fuel, both in terms of octane rating and "use this because it's good for your engine because it's got the unicorn jizz in it!".
