Anyone know how to take out the front and back speakers in an skyline r33 1997 model or where i can get a guide from? For the front speakers do you just pop out the grill or the whole door frame needs to come off? cheers !
Edited by sumguy
I tried to take off the passenger side door but i couldnt get the part off where off where the powerwindow button - that whole handle, it was just stuck :D
It's a barstard isn't it. There's a white latch on the underside which you hold and pull at the same time.. if and when you get it off, silicone it straight away so it's easier next time.
Where the handle is on the passanger door the actual handle that you pull to open the door from the inside has a plastic cover which unclips and there should be a screw behind it, its a bit hard to explain but thats your issue (i think) cos the same thing happened to me, you just forget sometimes where the little bastards are.
Yer, the pocket in that console... it has a round hidey-bit, with a little screwdrivery slit in it. Screwdriver the cover off, and unscrew the screw.
Then, the whole panel will come out.. it is just clipped in after you remove the screw.
Then unplug the power window switch console, or just unscrew the console out of that plastic part.
Window handle on the inside is hard to take off, but if you ease it to the left, it'll eventually unclip. From there, tug the bottom of the door, work your way towards the top. The doorskin is clipped into the door (after you remove the THREE screws at the bottom).
Then when the whole thing is loose from the bottom, lift up slightly to unhook it from the window-sill.
Pods are 4 screws. Easy out.
