Hey guys just wana see what yaz think is the perfect amount of balls for the street... Ill base
this on something like an R33 GTS-T. I will say something along the lines of about 240rwkw's,
second gear should brake traction for fun without clutching & scary gears like 3rd would hold
the road on most surfaces..
Give us some opinions or mabey even stories.. im bored.
https://www.sau.com.au/forums/topic/152649-opinions-perfect-power-for-street/
well.. in turbo cars if you have 240kw at the wheels, it is also a knob away with the boost controller to lower it down to say 190kw with a lower boost level. so yea thats pretty much perfect.
you dont want to be driving around on 16psi everyday to work @ 240kw, it starts to rain then before you know it your fishtailing 3rd gear with only half throttle on cheap ass Wanli's or NAnkangs.........
so id say for street driving 240-260kw @ wheels max for street DAILY DRIVEN, as long as you have a streetable clutch and diff and GOOD tires/brakes.
Why would you want to break traction on the street? Evidently one person's fun is another person's cock-knockery.
I'd want enough power to run a relatively hard touring tyre without having to worry about undue wheelspin. Something like a Dunlop 3000A or a Goodyear RS-02.
And I'd want to ensure that I wasn't running so much boost that I'd be unable or unwilling to drive my car every day in Australian conditions, regardless of the weather.
Even just the standard bolt ons (turbo back exhaust, FMIC, ECU + EBC) would be more than adequate for the street.
I got to agree with you
I would rather a car that grips well instead of a car that spins the wheels and dosent go anywere, also a well set up car handling wise is alot more fun than a car that has lots of power but dosent handle well and cant put the power to the ground around corners,a car that you can take round the twisty's and give a nice fast run is the setup for me.
no no no your fully wrong, go fullsik 400 rwkws minimum, that should get you everywere while the fuel is in the tank, no wheelspin what so ever, put some 285's on the rear and you'll be right :)
LoL, anything under 300 is the best bet for street, any more and its just rudiculous, 250 is comfortable, but as mentioned, with the right handling supports to accomodate power is your best bet for street
Yeah, for the street you don't need max power. You're either driving a commuter, where you only just need enough power to make gaps in traffic when overtaking, or you want a little fun "touge machine".
For the former I think the bolt-ons on a GTS-t would be perfect. For the latter, I'd probably prefer something like a RenaultSport Clio, DC5 Type-R or MX5. They've got a reasonable power to weight, flexible engines, and with not much weight but lots of grip they're fun to throw around your favourite winding road without having to do ludicrous speed.
Honestly, an SR20 Pulsar is about as much grunt as you need on the street for great fun. The fun is in the noiuse and reving the thing without going at crazy speeds. Hell my 800cc Handivan is still the most fun street car i have ever had...it sounded cool and use to rev it hard everywhere...and was always going at speeds which didnt make me fear for my licence.
In an R32 with a bit more then std poke i cant even floor it above 4k wihtout owrrying baout speeding...no fun at all
Yeah my friend was saying the same thing. In his sisters pulser he could thrash the car as much as he wanted and wasn't really doing dangerous speeds but in my gtr if you at the limiter in 3rd your at about 170km/h(i think) which is a bit scary on the streets.
Whats wrong with that :(
I had very badly worn Wanli's when I bought my car. Turning in the rain was always a joy. Power output was 193hp at the rears back then.
Launch out of first......hit speed imit...................hit red line, change to 5th and brake.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
