Hey peeps
Just a few quick questions,
I spoke to my workshop who said it maybe a better idea to get a Walbro pump over a Bosch as they are harder to mount? First up i have no idea where to get a Walbro pump from.
Im looking for about 350rwhp(approx 260rwkw), will a Bosch 040 do the job ok?
Also whats the Walbro equivilant of it if it will do the job?
Ive had a search through and found different ppl are on different levels with diff pumps but can't see if the Bosch 040 would make that power level ok (with injectors etc to suit obviously).
Thanks
Jaz
https://www.sau.com.au/forums/topic/152653-fuel-pump/
Hey peeps
Thanks
Jaz
The 040 would be fine for the power level you want to achieve or you could get the 023 (same size as 040 and still direct intank replacement) but they flow more.
Im against what TO4GTR said about the 040 cause i've had nothing but problems with the 3 brand new Walbro's i've had in 2 different cars but thats just my opinion.
At the end of the day its your choice what you go with but the 040/023 is fine for the power level your seeking and i think the part number for the Walbro equivalent is the 341 :happy:
GMB
https://www.sau.com.au/forums/topic/152653-fuel-pump/#findComment-2839685
Where can you buy Walbro pumps at a decent price from?
You can get 040's for under $250, are Walbros much more expensive?
There are a few sellers that stock Walbro pumps and they are around the same price of the 040 (depends on where you buy from) although you can get cheap Walbro pumps on EBay :happy:
https://www.sau.com.au/forums/topic/152653-fuel-pump/#findComment-2839690
Plenty of topics about fuel pumps under the search function, plus if your that affraid of mounting isues, get direct intank replacements, for a little more cash, and reliable as well. IE: Tomei direct replacement, at nengun.
https://www.sau.com.au/forums/topic/152653-fuel-pump/#findComment-2839751
Andrew sells Walbro 500hp pumps for 150 or so.. Check out the sponser section..
heres a link: http://www.skylinesaustralia.com/forums/in...p?showforum=123
I bought one, but havnt installed it yet..
I've heard alot about the DENSO intank pump they're based on the tomei pumps i think.. easy fit in R33 but a bit pricey.
https://www.sau.com.au/forums/topic/152653-fuel-pump/#findComment-2841197
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
