I have an avc-r installed and have made up a plate to go over the ash try hole but i wish to have someone fit it profionally into the hole so it sits flush with the rest of the dash.
Has anyone ever done this in an R32 in Adelaide? If so where.
Cheers Ryan
https://www.sau.com.au/forums/topic/152671-apevi-avc-r/
Cheers Ryan
http://www.skylinesaustralia.com/forums/in...st&id=67468
is that what you are thinking off?
https://www.sau.com.au/forums/topic/152671-apevi-avc-r/#findComment-2840778
ceedub.. thats the one bro. did youd do it yourself?
yep, just take the ashtray out and use a sharp knife to cut some material away so you can slip in the unit from behind the shroud (slip it in from the driverside. I superglued some metal brackets behind the shroud to support it so it doesn't fall.
I am sure there are better ways to do it.
In case I ever get rid of it I can always put the ashtray back in place
https://www.sau.com.au/forums/topic/152671-apevi-avc-r/#findComment-2843715
isnt the unit wider than the ash tray/ so there for if u put the tray back in it would look shiet
the unit goes in from behind so some of it is actually covered on the side.
Maybe I should check to see the ashtray actually fits normally - it was a while back since I did this.
I'll take some pic while I'm at it.
https://www.sau.com.au/forums/topic/152671-apevi-avc-r/#findComment-2846880
    • Hi everyone, just looking to see what's available in the GTR seat options, testing the waters on what's available. Wanting a driver's seat to replace my old school OG jap race seat, going to re-register the car so need a factory seat. Prices currently seem to go from $300 to $2k for a driver's seat. What's options are there, that's good condition and actually a realistic price? Located Brisbane. Thanks
    • Are these a plug and play setup, and do they need a tune, like a haltech ecu etc? Thanks
    • Nice work on the paint. Those 3 studs are long as.
    • Hi everyone, still chasing a bunch of this stuff. Thanks
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
