  • Replies 44
Steve You Smell. LOL.
I still have to come back to your place and get the compliance papers from your work.
Im a slack/ lazy boy.
Will see u out at the BSM cruise on the 4th. Looking forward to seeing u there mate.
Brenton.
P.S. there have been some slight changes to my car since u last saw it hehehehe
hey nisswreck,
im after a series 2 grill 96 model and a drivers side power window surround
not the whole assembly with switches just the long plastic bit,
pm me with some prices and availability
thanks
I'm pretty sure Andrew(Nightcrawler) on here in SA has one, prob with piping and all! You should hit him up a PM!
Actually I'm pretty sure that he doesn't have it any more. If memory serves me correctly Prof_dls bought his off of him & put in on the 33 he had before it was written off. Just happend to come up in coversation when I saw him at his place after the accident.
Could I also please be PM'd with a quote for a R33 S2 interior rear view mirror & for a passenger door attaching loop (I don't know it's proper name, the part where the door latches to the body) & a drivers side door trim. All need to be in good condition to be worth while for me.
Cheers
Edited by JazzaR33
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
