Just Engine Management - Dyno Day & Group Buy - Coming Soon 2007
J.E.M Exlusive SAU Offer
54 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 59
Posted Images
SAFC tune should be fine but ill verify that asap... hopefully in the next couple of weeks ill be able to get an official SAU group buy for all your dyno, tuning and ecu needs! but as i said prices will depend on intrest so more people = cheaper dyno, tune or custom package...
Cheers
When i last spoke to Adam at J.E.M he assured me that if we can get a decent number of people for ECU & Tune or Dyno Tune he will give us excellent prices. The reason why i setup the poll is to give him an idea of how many cars we will get for a tune... this will determine the prices.
People are spending thousands on performance products and for only 10 - 15rw/kw gain... so it makes more sence to me to get a professional tune for a lot less money and for 15 - 30rw/kw gain as well as reliability...
On the 20th of Feb my car is booked in at JEM for a Haltech E11v2 supply, fit and complete tune for $2800... This may seem alot but compared to other places this is quite cheap...with more cars, prices will be much cheaper...
TUNE HOUSE Quoted me = $3000
UNI GROUP Quoted me = $3200
HITMAN Quoted me = $3200
I got these quotes as a comparisson for you guys, I personally wouldn't let anyone touch my car besides JEM...
I'll be getting the Group Buy organised in the next couple of weeks...
Regards,
Sarkis
The Dyno power run is putting your car on JEM's Dyno.. Get 3 runs with a maximum power print out including:
- AFR
- Torque
- Kms/h
- RW/HP or RW/KW Graph
Adam will also let you know on:
- The general health of your motor
- If the car is running lean/rich
- Tips on what to do next to get your car running better.
Nothing on the car is touched... cause timing alteration .etc. falls under tuning and it requires much more time. So unless you got an aftermarket ECU, its pointless mucking around with little tweeks which will cost you dyno time..
A dyno power pass is MUCH more then just seeing how much power your car is making. Its also an indication of:
- How safely your car is running
- If your car is out of tune, timing or A/F mixtures
- As well as an indication if your car is running at maximum capability.
All that for $50 is peanuts! So lets start getting a list together of who is in for sure and we'll organise a Dyno Day... Maximum of 6 cars per Dyno Day....
Dyno Day #1 List:
1. jeffworld2
2. r32woohoo
3. lastlineofdefence
4. KIRUSS
5.
6.
Regards,
Sarkis
Edited by QRI05E
Thanks for the Positive Feedback stuartr32.. Adam is an exceptional tuner as well as a very honest an straight forward person. So if you want best quality and most friendly service... JEM is highly recommended!
Regards,
Sarkis
i would be in, possibly bringing some of the ctown thread guys, but i am on holidays from the 5-11th next month so cant make it then. if we get 5, can we come as a seperate group whenever we have time?
thanks for giving us this opportunity to do shit cheaply :pwned:
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
