Just Engine Management - Dyno Day & Group Buy - Coming Soon 2007
J.E.M Exlusive SAU Offer
54 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 59
Posted Images
SAFC tune should be fine but ill verify that asap... hopefully in the next couple of weeks ill be able to get an official SAU group buy for all your dyno, tuning and ecu needs! but as i said prices will depend on intrest so more people = cheaper dyno, tune or custom package...
Cheers
When i last spoke to Adam at J.E.M he assured me that if we can get a decent number of people for ECU & Tune or Dyno Tune he will give us excellent prices. The reason why i setup the poll is to give him an idea of how many cars we will get for a tune... this will determine the prices.
People are spending thousands on performance products and for only 10 - 15rw/kw gain... so it makes more sence to me to get a professional tune for a lot less money and for 15 - 30rw/kw gain as well as reliability...
On the 20th of Feb my car is booked in at JEM for a Haltech E11v2 supply, fit and complete tune for $2800... This may seem alot but compared to other places this is quite cheap...with more cars, prices will be much cheaper...
TUNE HOUSE Quoted me = $3000
UNI GROUP Quoted me = $3200
HITMAN Quoted me = $3200
I got these quotes as a comparisson for you guys, I personally wouldn't let anyone touch my car besides JEM...
I'll be getting the Group Buy organised in the next couple of weeks...
Regards,
Sarkis
The Dyno power run is putting your car on JEM's Dyno.. Get 3 runs with a maximum power print out including:
- AFR
- Torque
- Kms/h
- RW/HP or RW/KW Graph
Adam will also let you know on:
- The general health of your motor
- If the car is running lean/rich
- Tips on what to do next to get your car running better.
Nothing on the car is touched... cause timing alteration .etc. falls under tuning and it requires much more time. So unless you got an aftermarket ECU, its pointless mucking around with little tweeks which will cost you dyno time..
A dyno power pass is MUCH more then just seeing how much power your car is making. Its also an indication of:
- How safely your car is running
- If your car is out of tune, timing or A/F mixtures
- As well as an indication if your car is running at maximum capability.
All that for $50 is peanuts! So lets start getting a list together of who is in for sure and we'll organise a Dyno Day... Maximum of 6 cars per Dyno Day....
Dyno Day #1 List:
1. jeffworld2
2. r32woohoo
3. lastlineofdefence
4. KIRUSS
5.
6.
Regards,
Sarkis
Edited by QRI05E
Thanks for the Positive Feedback stuartr32.. Adam is an exceptional tuner as well as a very honest an straight forward person. So if you want best quality and most friendly service... JEM is highly recommended!
Regards,
Sarkis
i would be in, possibly bringing some of the ctown thread guys, but i am on holidays from the 5-11th next month so cant make it then. if we get 5, can we come as a seperate group whenever we have time?
thanks for giving us this opportunity to do shit cheaply :pwned:
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
