Just Engine Management - Dyno Day & Group Buy - Coming Soon 2007
J.E.M Exlusive SAU Offer
54 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 59
Posted Images
Date: 24th Feb at 10am
Venue: J.E.M - Moorebank
J.E.M Dyno Day List updated... Please check to make sure your name is on there otherwise PM me.
http://www.skylinesaustralia.com/forums/in...p;#entry2882490
Cheers
Edited by QRI05E
***URGENT UPDATE***
Dyno Day : 10/03/2007
Hey guys, I just got a call from J.E.M
J.E.M Dyno Day has been moved to the 10/03/2006 due to last minute urgent request. Adam was called to go to Perth for the National Drift Comp 2007. And the weekend after he will be attending Power Cruise 2007 so the next available day is 10/03/2007.
On behalf of Just Engine Management I sincerely apologize for any inconvenience and hope this official date will be okay for everyone.
Regards,
Sarkis
Yea i know its bummer but these last minute changes do happen in life... I hope everyone will be fine for the 10th of March.
Please let me know if theres any issues.
Regards,
Sarkis
Went and saw Adam today at JEM, his a mate's mate. He was saying that the dyno has been moved to around March 15??
Anyway....had my R34 dynoed just to check the fuel mixtures etc. Car is currently stock as a rock and managed to pull a healthy 150kw with 20s on.
According to him my motor is apparently very healthy and can manage 200+ kw at the wheels with a nice cooler and exhaust and maybe a little bit of boost increase. Was very happy to hear that :happy:
  • 3 weeks later...
J.E.M Dyno Day
This Saturday 10/03/2007
Time: 10am
Location: UNIT 3, 10 HELLES AVE MOOREBANK, 2170 SYDNEY, AUSTRALIA
Map
Check the list and make sure your name is on it!
PM me if your coming or bringing an extra car to dyno
1. jeffworld2
2. r32woohoo
3. lastlineofdefence
4. KIRUSS
5. Phillip
6. MR 33
7. ufoboy
8. Risking
9. Aarlan (R32 GTR)
10 Tim (R33 GTSt)
11. Paulo (180sx)
12. Jim (Starlet Gt)
13. David (Corolla Sportivo)
14. Will (180sx)
15. Jordan
16.
17.
18.
19.
20.
Cheers,
Sarkis
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
