hey ppl,
have many people on here had re-map from dr.drift who can share how everything goes now, im debating between re-map and greddy emanage ultimate. re-maps heaps cheaper.
mods will be upgraded turbo, injectors,cams, fuel pump around 230rwkw. nothing over board on r32gtst rb20det.
is there any advantaged with the emange in the long run being easier to tune when its set up or there both the same just the inital set-up of them both
thanks all
simon
https://www.sau.com.au/forums/topic/152690-dr-drift-re-maps/
I can vouch for Sam's remaps and his tuning...he's remapped and tuned 2 of my cars to date and i haven't had any problems...for cars with ecus that can be remapped...its extremely good value for money...
And 89 SIL...sam sometimes puts a tuned by dr drift sticker on the ecu cover if he's done a remap but thats not always the case...
Edited by limpus
  • 1 month later...
i can vouch for his style of tuning.. i have a mercury motorsport ecu tune which is using the software they bought from dr drift
tune is great and retains stock knock sensors and cold start etc.
only problem is that if you want a re-tune then there's only one place you can go...
with things like a powerFC, you can pretty much go to anyone to get a tune
i had him remap my car a while ago, he wasnt to familiar back then with rb20's he was doing heaps of SR's
i would recommend him to anyone in melb but if your in sydney or bris not only do you pay for the chip but your paying for his time and the cost of the dyno he is renting..
he came twice to sydney to sort things out for me. so $300 for chip and 2 dyno sessions which cost about $300 each. another problem is if something was to happen you would have to wait a few months for him to come into state.
so i wasted about $900 all up on nothing and in the end i switched to an Fcon.
Sam (Dr Drift) tuned my R32 RB20 to 220rwkw without a hitch. Can easily tune up to whatever limits your bolt ons have. 230-240-250+ rwkw even over 300kw can be handled by the stock ECU. The only limit is your engine and mods (especially airflow meter).
I have had no problems with mine and will always go back to Sam if I need more power.
Would recommend to anyone.
PowerFC can be tuned anywhere by anybody, that is the real advantage.
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
    • I'm pretty sure if it's considered a gasoline powered vehicle you have to do certification against a fixed, very expensive certification fuel.  If you add two precats and then replace the main cat with two cats back to back you can get an RB26 to do 0.24 g/mi HC, 1.6 g/mi CO, and 0.3 g/mi NOx on the FTP-75 drive cycle. Found this out courtesy of California's laws at great expense. Divide by 1.61 to get g/km. So even with extra cats + precats you're blowing past the NOx limit by probably 2.3x. Probably the only way to get an RB25 or RB26 to meet euro 4 purely from an emissions per km standpoint and not durability/OBD2 requirements is retrofit at least intake side VVT, clearance the pistons to allow the full 50 degrees of advance so part throttle EGR can be maximized, and change the wastegate control from conventional 7 psi spring for example to one that is always fully open if the wastegate line is at 1 atm or higher and only close it in response to vacuum. See BMW's N54 engine as a reference for how this works. You would need to find space for a vacuum tank to function as an accumulator in this system. That way you can avoid any heat loss to the turbine as much as possible during cold start to heat the catalyst faster. Then find some way to eliminate as much as possible cold start enrichment to light off the catalyst rapidly. Maybe secondary air injection if there's no way to avoid cold start enrichment. Close coupled catalysts in the downpipe are probably necessary. I would also probably swap to EV14s, pick something with the correct spray targeting + dual cone pattern for the intake manifold you're using. EV1 style injectors to pass anything resembling modern emissions requires a very annoying air assisted injector system to break up the droplets at part throttle/idle which still doesn't work that great compared to just having smaller droplets from the injector to begin with. Realistically, you're probably going to be financially ahead if you just pay the fines instead. Or don't drive it into the city center. There's a reason why Nissan never bothered to even attempt certifying an RB for CA/US emissions. The VG30 needed external EGR on top of NVCS to pass in the 90s. Doing all of this work is also distinctly expensive and you're going to struggle to find anyone who is remotely interested in helping.
    • I remember those, people use to steal them to make bongs.....
