post-6176-1169363232.jpgpost-6176-1169362951.jpgpost-6176-1169362827.jpgpost-6176-1169362647.jpg1998 suzuki swift gti , silver in colour with 8 months rego. 113000klms. this car has jap spec cultus g13b engine 85kw instead of 75 kw. i bought this car 8 months ago when petrol was at $1.40 plus a litre and my skyline was in the shop having its engine rebuilt. now i have my skyline back and the wife has said that one of them has to go, so iam selling the swift.
this car is very reliable and economical giving fuel consumption figures of 6.4/100klms city and 7to 8litres per 100klms for city driving. this car would be ideal for someone who owns a skyline that is very thirsty and they do not want to rack up too many kilometers on there sky. or a first car .
the car comes with sports steering wheel , cd and pioneer 6x9 speakers. extractors ,sports exhaust. lowered sports suspension with brand new kyb front struts. tinted windows. 15x7inch alloy wheels and near new 195/50 bridgstone turanza tyres. pod filter. chipped ecu. this car will rev past 8000 rpm!!!!
iam looking for $8500 ono
Edited by bigcarl
https://www.sau.com.au/forums/topic/152691-1998-suzuki-swift-gti/
  • 5 months later...
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
