I have just found that my stock aribox has slowy broken all the clips off. Except 1.
What I had noticed on full boost the other day I chagned gear and i heard a funnny noise and than a metal sound hitting the pavment. Thought was a hose clamp at first. Anyway lost another clip to my airbox.
Now I have an old air filter that needs to be changed. So thats on the list and well was going 2 get a new airbox at the same time.
I have an R32 gts-t (One in my avatar) Stock BOV, FMIC , and Bosch 040 Fuel pump.
Running aprox 12pound of boost. Before changing intercool from stock, I noticed that my airbox had most of the clamps broken on it.
Now thinking it might have something to do with high boost and stock bov wich is plumped back into the system.
Questions.
1. Is this a normal thing?
2. will this screw my air flow meter
3. What can i do to fix it if it's a problem.
Anyway got anything you want to say just though it in.
Thanx.
check ur filter is a tight fit. SHould be around the rubber seal.
Get some of the good tape, gaffa type..u find it at Bunnings and is the material type, wide type...use that to secure it until u get another box 2nd hard on this site.
OR try and fix it...
Sounds like he wants to replace the airbox, I dont think 12psi of boost would cause the problem - your car is probably 15 years old? I imagine the parts may have perished over that amount of time...
Would you get another air-box, or a pod filter?
Yeah she's held together by a cable tie at the moment.
Thank god for cables ties.
Yeah, dont realy want a pod filter. So prob hit the jap wrekers for another one. However I will probably get another 15year old one,
Might get another one and add a bit of arredite to it for extra strength.
    • I've watched some vids and the technique seems to be to butt the sheets up to one another and use MIG to spot weld and slowly fill in the spots until its eventually all sealed. No runs as you would normally do, as there's too much heat generated that way. Yeah my stick welds are terrible these days because its been so long since i've done any of it. I expect to be spending many hours practicing
    • I have personally seen a Tomei USA RB26 cam that didn't even fit the head. Kind of nuts to me that it was even possible for that to happen but such is life.  There's two UP Garages in the US. One is a US branch of the Japanese company which sells things they brought over at tremendous markup. The other is University Place Garage/Fairlady Motors which is a shop best known for putting VCAM in RBs and trying to convince people to stop putting in 800hp of turbo on a 2.5L motor.
    • Gasless MIG is not exactly suited to what I would call "delicate" or "attractive" welding. So I would rule it out for sheet metal rust repair type stuff, unless you're only doing it in hidden places. I'm thinking about getting myself a gasless MIG for "hack together" type work. Noting that my welding experience is very very low, and quite a long time ago. So I'm also looking for "simple", but I'm not expecting "excellent". I'm not even sure that proper MIG is the best for sheet metal work. I get the feeling that the degree of control and the minimisation of heat input that you get from TIG is probably what you really want. And then you have to get good at doing it before the welds won't look like a monkey flinging a handful of shit anyway. You're probably SOL for an easy and cheap way to get from where you are to where you want to be. Much like myself.
    • Any recommendations for what would be the easiest welding type to start on, for sheet metal rust repairs and maybe some exhaust piping too? Seems like MIG is the most common. Would gasless MIG be ok to learn on and do some simple jobs? I have a stick welder which has a Lift TIG setting, but i'm more interested in getting whatever's easiest to do, and most suitable, rather than using what i have.
    • Is the UP Garage in the US of Ayyeee even the real UP Garage?
