starting this thread for anyone who wants firmer shifts in there auto without a shift kit . was having a few problems wit my trans slipping in third gear and first so took her to the shop. The car has a warranty so told the guy while it was appart that i wanted a shift kit installed cos it would be cheaper. when he called back he told me that i had a leaky solenoid and there was a lot of tarnish on the valve body, then he mentioned the Shift Improver and from its description could probably claim it under warranty. It claimed that it would extend gearbox life by firming up 3rd quite a lot and other gears aswell. the shift improver cost round 250. This is a good idea if you want firm shifts but not a shift kit as they can change gears alot harder. anyways i am happy with the end product. nice firm shifts that dont break ya neck. has anyone else had one installed.?
https://www.sau.com.au/forums/topic/152782-auto-shift-improver/
its modifying the valve body. bigger springs new valves and drilling bigger holes in a plate to let more fluid through to firm up the shift .its like a shift kit just a mild one but stiil gets a heap better shift than standard
There are different versions of shift kits available from MV Automatics in SA (stage 1, 1.5 and 2 i believe), I went for the Stage 1, the mildest, prob similar to yours, only feel the changes from 1st to 2nd, others are smooth, but very quick, no more flaring.
Not sure what stage I got but I had mine installed at MV automatics (I live in SA). $440 including a transmission service so not expensive at all.
My shifts are pretty much transparent when I want them to be or a bit more clunky if I drive it hard. I normally feel the 1st to 2nd shift but after that its unnoticeable.
Like everyone else, I get very solid, quick shifts and I'm very happy with that little mod.
And yes it apparently improves your auto box not weakens it. :glare:
it saves your clutch packs from slipping before it is fully in the next gear by letting more fluid through the valve body to push the packs together quiker. you have 2 sets of packs. 1 for 1st and 3rd gear and the other for 2nd and 4th. the weakest shift is 2nd to 3rd.
No, it is a specialised job, there are only a few places who know what they are doing with the RE401 boxes. If you have the time, get a shop to pull out the valve body, (or better still, find another one), then send it to Mike at MV Automatics in South Australia, tell him what stage you want, he should send it back after a couple of days.
Edited by chook
    • Yep that makes sense, thanks! I guess flogging these turbos in winter is more preferrable lol.
    • Bahahaha, bloody hell Greg. You've got bent and broken things, but instead, you're replacing perfectly good items. This story keeps getting more gregged!   Also, I'd 100% replace that reo if I were in your shoes, unless you panel beater is REALLY good. Even if you put another GTT one on there. Just because you've done so much nice body work lately, I'd say repair the body work fully  If it were more drift car spec, I'd be all "Hit it with a hammer and send it!"
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
