hi there folks
for sport compact drag racing fans you may be interested in visting my site, its just up this week, i am yet to add videos of all the low ten second passes. it will be updated with race results changes to the car and anything sport compact drag racing related.
any thoughts are welcome
cheers
shane :P
https://www.sau.com.au/forums/topic/152822-www1jz747comau-is-up/
looks cool. whens the car coming back out?
should be around late feb to go testing ready to race at marc 10 sport compact
then race march 31 at qld
then front half of cage goes in an parachute and we should achieve 9.5 to 9.6 et at high 140 mph in may for rays 4th round.
how are things progressing with you lee?
easy, put it in a skyline. i know someone selling a 32.
Getting there slowly.... Think I have the converter sorted out now, getting a CDI in a couple of weeks and then it should go ok.
I need to work out how to get a bigger dump pipe to fit though.
thats really coool.
oh just out of curiosity. was there a big diferance between your old turbo in regards to lag.
if so what sort of diferance. cheeres. im thinking of upgrading the t04z
i cant really give a real comparison as when the 51r was taken off the rear wheel had 10mm missing off each blade.
    • Hi. I need a new clutch for my gearbox. It is a factory smallbox behind RB20DE NEO. What options do i have? If iam not mistaken the gearbox should be the same as in R32 GTST and Nissan S14/S15? I found some Xtreme Clutch Stage 1 for S14/S14 (i dont know if you know the brand) (UK) OR...is the clutch same as in the bigbox from RB25DET?   Thank you!
    • Listening to an artist called "the flashbulb". Not bad. Makes some fairly well researched youtube vids in various things.
    • Is actually easier than you might think. Assuming you have a spot, youfab up the branch, then just hang a longer than you can fit length of pipe down from there, and chop bits off piece by piece and decde which length was the quietest/nicest, then just put that length up in the place where it will fit. Clever folk can actually make like a trombone slide type arrangement so you can just play it like an instrument to find the best length.
    • Buy her some ear plugs.   Or, wear earplugs so you also can't hear Jackie whining...
    • Necroing this thread in 2025 to say thanks! The Manual for the m60 still has the wrong instructions and says to only press button 2 with ignition on. You are a champ, thank you.
