Hi i have a r34 sedan. Just wondering where can i get it tinted to the darkest legal limit for pretty cheap, i just dont want it to bubble after a while so something half decent. So where is a good cheap place to tint my car in the south east.
Thx
All
https://www.sau.com.au/forums/topic/152839-where-can-i-get-my-car-tinted-cheap/
not that far mate, took me 30 minutes
PM Sam (Baysidebluebnr34) on these forums, and ask him directly what you want, and see if the drives worth it
Nah i just cant be stuffed going all the way up there id rather just pay a little extra.
southside window tint beenleigh thay done mine 4 good price if thay say over 200 pm me and i will ring up 4 u kool 0409499409 ask 4 dean if u can
got mine done by the same guys.
jason is the guy you want to speak to. i think they work from home now.
they are really good guys - my driver side tint ended up having a bit of grit inside, and my passenger side didnt exactly line up properly when the door closed (glass moves abit when door opens/close). and they fixed em up free of charge.
not the cleanest of photos. but its a quality job
Thx guys i will call them probably in a month or sooner appreciate everyones help gonna go save this number somwhere lol.
Theres a tint shop on sandgate road on the left hand side of your road just as you come out of the tunnel past toombul shopping center (heading away from the city). They've got a sign up advertising a full tint for only $99, after talking to a few mates apparently they do a good job too, thinking about getting my car tinted there.. If you're interested I can find out the name for you :happy:
check my sig he is mobile too (area depending)
did our corolla post-146-1169986827.jpg rear is darker then front to protect my little boy T15 & T30
How much was it to do your corolloa and is the rear one legal.
All suburbs around brisbane are ok just not more then 15 minutes from brisbane from any side.
make sure it is a place that does the rear window as 1 piece, instead of as 2 or 3 pieces. my mate owns an ultratint (but its in gympie) and he does all rear windows as 1 piece. that way you don't have the tint bubble along the centre join after a few years.
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
