hi guys
tried searching but no luck
i thought this would be the most appropriate section to post in aswell..
anyone know if the two rear tow points can be removed or are they actually bolted to the car? im fitting rear bar on my vehicle and just need to cut a bit off them and wondering if i could remove them without cutting them if not ill cut away, when my rear bar goes on you cant see them anyway so no point them being there
thanks
https://www.sau.com.au/forums/topic/152845-r32-rear-tow-points/
i ahve installed a vertex bar on a 32, the tow points are welded on, no way to remove.
i just took a slither off the point of them and the bar fit over it great, just remember to paint it once your done.
