Hey ppls,
I started to rip the car apart in an attempt to replace my climate control inlet air temp sensor and heater core that is leaking.
I remember when the car was like new and had 60k on the clock around 5years ago, the air out of the dash vents would hit my face hard and cool the car and myself down quick. These days its a real struggle to adjust the vents to get a nice cool breeze on to my face, I have to direct both center vents and close the 2 outer.
Pictures say a thousand words.
As you can see the a/c/heater core (unsure which one it) is is blocked with crap, u can see the fins towards the front where I scraped a little of the junk away.
Unbelievable. ;)
Yeah if you park outside alot all the ducting will get blocked up with leaves and crud. Also a good idea to clean it out the cores and boxes with soapy water, as any crap in there is directly related to what you smell coming out of the vents.
BTW: A/c core (evaporator) is a separate core to the heater core. From left it goes blower box, evaporator box, heater box.
Edited by Godzilla32
Hmm, that vent doesn't look familiar, but mines pretty shagged at the moment, not very cold and sometimes vents dont open fully, so i was hoping to clean it out/maybe replace the motors
Ne ways, how did u get to those vents? Are they up behind the dash? Did u need to take the dash off? thx
Dash has gotta come out but its pretty basic once you got the stereo etc out. Two bolts up top under covers and a couple more on the bottom corners. However before you remove the top section of dash you gottta take off the sections that are attached below that. Before you go pulling it apart do a search on climate control diagnostics and test it out to find out whats actually wrong with it. Might save yourself alot of time. Possibly you have an A/C leak and thats why its not as cold.
Deren
If you think jap cars are bad rip apart a VS Commodore dash. :S
They are never the same afterwards, no matter what I did it would squeek rattle and that was when it was only 3yrs old. :S
The jap cars are quite good. Just be carefull not to break anything.
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
