hey guys, ive had air con trouble since i bought my gtst. No cold air
Ive since fixed leaks and replaced faulty sensors. Now diagnostics check is good, BUT, my compressor does not kick in unless i overide the computer by touching a wire from the negative terminal of the battery to the pressure switch at the front of the car where the gas cylinder is. Then the compressor kicks in and i get cold air.
mechanics have told me it could be the thermostat, and that i should try overiding that to see if its faulty. what i dont know is exactly where the thermostat is to put a wire in to overide it?
can someone post a photo or describe where this unit is, and where the connection is to overide?
Edited by Archie
The switch on the top of the dryer ( the gas cylinder thing ) is a pressure switch, it stops the compressor kicking in if you don't have enough pressure in the system. 'If' you have the correct amount of gas in the system, and bridging out the pressure switch gets it all working, wouldn't it appear that is a problem with the pressure switch?
Edited by heller44
check wether pin 9 on the eccs is going low 0v when trying to cool on air con. if not, then check pin 46 on eccs if that is going low 0v. pin 9 is out to pressure switch to pull aircon relay in, pin 46 is in from auto amplifier (climate control). If you don't get it there check pin 15 on climate control thats the origination point.
If your diagnostics on all sensors are good, this is about your next step.
yeah, i had the car at the mechanic today, and he told me that there was a problem of something not earthing somewhere. i think thats why the compressor kicks in when he bridged to the pressure switch from the negative terminal of the battery.
With reference to the diagram, all you are testing doing that is that the aircon relay works and the compressor clutch works, not all the rest of the crap which controls it.. the ecu is what turns on the air con relay, it is just told to do it by the climate control module.
You say you've had sensors replaced.
I have recently had the exact same issue and it turned out my Intake air temp sensor is constantly reading -30degree's (occasionally comes up to 8degree's or so).
This stops the a/c compressor cutting in.
Have you entered the climate control diag mode and had a look at the intake temp sensor reading?
Mine doesn't always show up the Intake temp sensor in the sensor check.
The only way to be sure is for myself to flick to the sensor display and check them.. Often than not when its -20 it doesn't show as faulty but it sure isn't -20degree's so its faulty and causes the a/c not to operate.
Did you replace the Intake temp sensor? I can't appear to find the sucker.
yeah im pretty sure i did replace that sensor. i had to remove the entire dash (which took a long time, but i was being careful not to damage anything, cos you so easily can) and then where the aircon box is behind the glove box, the sensor is one of the 3 connectors that sit on top of the aircon box.
Its the left, white connector. The middle one is black (thats the refrigerant temp sonsor connector), and the right one is white (that connects back to the climate control unit).
The actual intake air sensor is inside the aircon box (if you follow the wires you'll see). i had to pull the stuffed senor out (forcefully) by yanking the wire and dislodging the sensor. then i inserted my new second hand sensor (which i pulled from an old aircon box to get the spare intake sensor). i pretty much just had to let the sensor hang inside, cos otherwise i would of had to degas the whole system and then remove the aircon box and open it up. But i had just had it regased so i wasnt gonna do that.
Now ive just found out that my water temp sensor is showing up on the diagnostics check (No. 23 flashes)
Would this sensor be enough to stop the compressor from kicking in? And also, is this sensor under the car?
thanks cubes.
Hey, where abouts in SA are you? Ive been going to Synergy Motorsport at Medindie Gardens on main north road to try and get this aircon bullshit sorted. Im not sure if they still are PVP imports anymore aswell as Synergy?
Cars been good.
Owned it for 5yrs, clocked up ~160,000km's of my own and now its starting to show its age.
The clock states its done 230,000km's.
Just bought myself a press and bushes for the front and rear I will be doing them once I get this aircon sensor and track down heater core for a reasonable price.
The highpressure aircon hose recently went after a conversion to 134a (134a runs double the pressure of the old R12 gas).
The top radiator tank let go in the early days, Natrad in the city replaced that for $90.
Clutch master and slave cylinder went, they were $75 and $30 each bran new. All Clutch and Brake at St. mary's does them so look in the SA sections workshop sticky.
Nothing else really.. Its been a great reliable car.
Only replaced motor as I got tired of the rb20 and had been building up the 3ltr for a couple of years prior so ripped it out sold it and dropped the 3ltr in.
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 🤣 And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 🤪
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
    • What ecu? Same shop every time? Same ambient temperature? If timing is correct then pull plugs and see if lean or rich. Dyno can also read different if they have changed ramp rate or not set tacho/speed properly
    • I've never done dial in's just straight up, whatever that's called. I'm far from a drag (racing ) expert.
