  • Replies 100
Very Cool....yes......fit......no.....:D
unfortunatly the offsets on the Racing Harts arn't right for the skyline an hit the front calipers (would need a 8-10mm spacer). So im back to looking for some rims unfortunatly. Aaron already said I could trade for something else he has if I like or will search down something particular for me if need be. Dissapointing for now....but in the end i'll still end up with nice new shoes.
bad luck. I'm going anther set of bronze WORK rims...just a bit cheaper than the RAYS but still good. THen i have some $$ for the RE55s...
the rims were 18x8 fronts and 18x9 rears with +28 offset. Which will fit a skyline depending on spoke design, these particular rims have very flat spokes, which I think means the X measurement isnt right for my car (hub surface to spoke surface distance)
so if anyone wants some cool rims for there 31...reckon these would be sweet (Racing Hart CR, about 1.5 inch dish front about 2.5inch dish rears, multi stud 4 & 5 x 114.3)
cheers
CRACK: the rims in the powerplay link you put up are identical to what I have sitting in the shed. I'd say the rears are exactly the same with nice dish, but the fronts on the one in your link have nealy no dish compared to what I have here. Not interested in no dish......must have DISH :wave:
any ideas on great set of rims?
Ideally I want Volk GT-N or Blitz Technospeed Z1
Still like Volk GT-C's, maybe Racing Hart CXR or C4R's. I've been searching through Yahoo auctions for ages an so far havent come up with much.
he seems to have removed em......
heres a link from the previous page of this thread of the pic he gave me of them before they arrived here.
Racing Hart CR pics pretty small
ill get off my lazy ass one day an take a photo
Or these ones...
RAYS VOLK RACING TE37
18" = $631.793 AUD per rim (offsets: 12, +22, +35, +40) (Size: 8.5,9.0,9.5,10.5)
19" = $681.876 AUD per rim (offsets: +5, +12, +22, +34, +35, +36, +43, +44, +45) (Size: 8.5,9.5,10.5)
Where'd you source those prices?
edit: what blitz rims kel?
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
