hey guys cheers for those that helped me with the oil bracket issue
got another thing ere
i been wanting to fit in my z32afm s15 injectors, bosch 040 and turbo for long time now, yet if i get somebody to put em in or do it myself yet without changing the ecu it wont run and even if i plugged in the new apexi thats coming.. how would i get it to a tuner with all the mods without damaging the car????
am i suppose to get somebody to install them and tune it at the same place?
or do the work in a garage and tow it to a tuner??
i do not want to wreck my car or the sensors.....
https://www.sau.com.au/forums/topic/152924-quick-question-on-modz/
i would install everything
then in the pfc you can set it to use the Z32 afm
then input the injector latency and correction outlined in paulr33's PFC FAQ. http://paulr33.skylinesaustralia.com
then drive it on the box tune and dont get it on boost, watch the knock reading and get it tuned.
Edited by Craved
exactly the pfc has a base tune that will alow the car to run. but run only, so drive carefully and like craved said watch the knock sensor for high readings. But only install all the things you know how to do properly otherwise you'll run into serious problems half way through and cause more hastle for the person who has to fix what you stuffed up causing more time and you money! Most workshops would easily be able to do all of the things you are getting done. But watch who you get to tune your car as thats the most important part.
good luck
matt
Edited by 33NIZ
good luck
matt
ohh i see i see, so the pfcs oready have a base map and can be tuned also from paulr33's instructions... nice, i will most likely get it all installed together at a workshop ( garanteed work ) and then drive it off boost and cautious to thre tuner ( maybe 5 mins away )?
i was talking to a bloke at tune house, seems to know what his doing with the power fcs?
thanks agian guys :)
Edited by Zas)-(
    • Thanks for your insight, it being basically useless will impact my decision for sure. I thought it may help the engine breath better I guess. But then again, I have also been told that tuning an RB20DE is also not worth it. Exactly, we follow EU Regulations. There is a bit more leeway on older vehicles. My Porsche 924 came without a cat from factory and managed to pass, they still mentioned that I have quite high emissions on it though.
    • My apologies, I stand corrected. Thanks for registering to mention this! And thank you for actually reaching out to the council to clarify. This is the sensible thing to do and the opposite of what I was alluding you were doing. I may have seen too much outrage and hate being fueled on the internet and it has made me a somewhat cynical old man. Sometimes it is easy to forget that there are real people behind websites and accounts. In my defence, CarExpert and CarExplore do read quite similarly at a glance. I shall try and do better in the future. (Please stick around to get the latest scoops on dealing with old Nissan shitboxes )
    • Don't bother. The poor little RB20 doesn't make enough gas flow to challenge the flow capabilities of even the littlest cat, and you won't make any extra power, and all you'll do it soot up your rear bumper. Plus....is Malta not runing under Euro regs?
    • Hey Daniel, sorry to hear that and thanks for posting up for us at a really hard time I only knew SmoothLine through the forums, we never met as we are based in different states, but when he was most active on here he was quite a while back so not many of the current crowd might remember him. I am pretty sure he was active in the Queensland SQU club but that is defunct now too (times are changing and we are all getting older). Farewell SmoothLine!
    • Turns out depending on whether the car was equipped with TCS or not there are different signals coming to the dash, meaning there are different speedo clusters.  Wired in a speedo calibrator box from aliexpress and now works fine.
