Ok so there has been a bit of idle chit chat lately so i thought we would try a spotted thread for all you die hard posers :(
To get the ball rolling i spotted a very 2nd hand looking 32 that someone wants to swap for a A31 track car with all the goodies :laugh:
Knock yourself out people but dont abuse it, you want to post crap then take it to Whoretown :glare:
Cheers GMB
https://www.sau.com.au/forums/topic/152949-tassie-spotto/
SPOTO, Young GTR on the way to work in the NEW GTS2. Looks sweet, sounds good.
GMB , can we have discussions here about the cars spoted or just spoted.
Discussion to a degree but if you want to talk sh!t then take it to whoretown :devil:
https://www.sau.com.au/forums/topic/152949-tassie-spotto/#findComment-2845382
Spotted a LIME GREEN R33 with Veliside Kit front on hedding down past town outside Cathedral at about 3:30pm Monday 29th jan
:D you dont have to give us the full run down ya jack arse!!!
Im supprised you didn't post his rego, what he was wearing and if you thought his BF was good looking :(
https://www.sau.com.au/forums/topic/152949-tassie-spotto/#findComment-2862824
Well i figured that was a bit muhc, but his plate was FG3476, and he was alone. LOL. Nah i just made that up, JACK ASSSSSSSSSS.
Also spoted and white R33 an white R32 and a Black R32GTR all heading down the brooker last night.
https://www.sau.com.au/forums/topic/152949-tassie-spotto/#findComment-2863242
Probley Alan (al r33)
Nar it wasnt me i havent had the car out since the weekend! But there is another one people have told me about which is allready causeing me trouble with the cops! "Booked for Drifting on Kingston Beach Esplanade" when my car was not even on the road and at the mechanic getting suspension changed! I had to take it to court but i won in the end!
https://www.sau.com.au/forums/topic/152949-tassie-spotto/#findComment-2863970
Yeah i know the car your talking about, he is one guy that gives people things to bitch about import owners :wave:
https://www.sau.com.au/forums/topic/152949-tassie-spotto/#findComment-2864105
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
