Never seen it in the flesh, only in his signature (which doesn't show a huge amount). I'll take a look around on here for some higher quality pics and keep an extra sharp eye out for it out on the street. Sounds like a horrific crash with the blue 33, I had no idea... Horrible to see yet another one go to waste
Going to stop spamming and busy myself elsewhere for a while as this is hardly spotto-ing :rofl:
well empra was rolled into a brick wall and suffered quite a bit of damage, this was a few months ago though.
The front bar has a bit of damage where it looks like it's curled under the car and the bonnet looks a little bit long on the body (but I think that's just aggressive styling) as you can see in the picture. Either I'm seeing ghosts or she's back on the road with any major front end damage fixed and a patched paint job.
Pretty damned sure of the days I saw her, as I was scuttling back from work in the blistering sun attempting to look like less of a blob of sweat (being Tasmanian anything over 25 degree's is like an oven to me).
woulda been yup :) was on a cruise for a mate. what the hell was going on in cygnet??? like a bajillion people there
More than likely the redirected traffic from Margate due to the accident.
there's the cygnet folk festival (read: hippy festival). im staying with some friends - last night i went on down to huonville in the GTR and ended up in the middle of a cruise.. i was like what the hell! last thing i expected to see down here :)
there's the cygnet folk festival (read: hippy festival). im staying with some friends - last night i went on down to huonville in the GTR and ended up in the middle of a cruise.. i was like what the hell! last thing i expected to see down here :(
haha i heard there was another GTR down here over that week. every one was telling me how nice it looked.
Spotto'd Funz in Kermit and a guy (I'm assuming Mr. Untouchable?) in his dark grey/silver R33 at the round about near the fork in the road today, and a nice white series 2 R33 a bit further down the road. Attempted to get an arm out the window for a wave but my drivers side is stuck closed :(
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
