i was watching targa :D
you were better off. I Had a squiz on saturday. Considering it wasn't wet there was a few offs!
powercruise was shithouse I reckon, the last 2 were reasonable. I wont bother going back ever again.
Edited by Mr. Untouchable
bugger that. too much exspense for too little race time. I'm thinking along the lines of super series. targa b sorta thing. mm maybe in a year or 2.
then again there's a few stacked up targa cars at work that would go cheap lol
would be fun as i reckon, out of interest how much have to set aside to make your car compliant to targa regulations funz? Saw around 8 skylines all up in targa and on the woodbridge hill there was an SL/R5000 on the back of a tow truck with a sore nose.
biggest cost that ive encountered atm is rollcage and seats.. and thats not including the cost of entry fee, new semi's to run with and general maintenance to run the car and also the fact i need to buy/get built a hi flow turbo :) all this stuff here is looking at 8k+ BUT i plan on running the car in hillclimbs and track days all the time so im not just spending the dosh for targa :D
www.targawrestpoint.com.au has all the regs on what you can do :-)
Good luck getting the 350 passed for Targa with the engine mods!!!
he doesnt have any engine mods :S lol
Just spotted some BS^^^^^^^^^ :P
Also saw the red R35 this morning in Salamanca
what BS you talking about lol... me rather confused lol
BS is IN BOLD ya computer tweaking geek!!!
YUP! pretty sure i remember seeing this car about at powercruise!
Should of come and said hi :D
Some dude named chris got some footage of me so i asked for the rest and here it is!
Fking RED Holden Drives taking off like grandma :)
Its ok there was like 10m room but you cant see in the vid !!
http://www.youtube.com/watch?v=pQ9-PgPNvBM
and that footage shows exactly why I couldn't be bothered with Power Cruise.
Get out there on a proper track day with only 4 or so cars and full use of the track...
Much more fun if you ask me :blink:
And yes I am friends with the guy whos car the footage is taken from and also the guy in the "Fking RED Holden" as well.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
